I imagine that you are setting the 'Darkness' of the print, correct? When you exit the menu, you will be asked to save. Be sure it says "Permanent" in the LCD and then press "Next/Save" key to finish the process. If it does not save, you may have a problem with your MLB or memory.
I am having trouble with the preset label configurations, where the ribbon prints off the bottom of...
(More)
I am having trouble with the preset label configurations, where the ribbon prints off the bottom of the label. I need it to start about 1 cm higher... Can you point me in the right direction?
printing duplicate tags, the print is not in the same spot it moves 1/8 of an inch top to bottom it...
(More)
PRINTING DUPLICATE TAGS, THE PRINT IS NOT IN THE SAME SPOT IT MOVES 1/8 OF AN INCH TOP TO BOTTOM IT IS GOOD SIDE TO SIDE.
I am trying to run two 140xi iii's from Easylabel Platinum, i have one set up through a parallel...
(More)
I am trying to run two 140xi iii's from Easylabel Platinum, i have one set up through a parallel port (LPT1) and the other setup through a serial port (COM1). No problems with the printer running through the parallel , but cant get the printer with the serial cable to go (when i send a test print through the data light flashes once and then nothing). Any advice is much appreciated!!
