Question about GE JVM1850 1000 Watts Microwave Oven
How do disassemble the door in JVM1850B
I have a JVM1850B and i broke the door handle. I found a new door handle in one of the online parts site. I can only see the front end of the screw that holds the handle but could not reach the backend of the screw to fasten the handle. How do i open the front door so i can fix the handle? Any hepl is much appreciated.
  • GE Master
  • 9,098 Answers
You can find helpful exploded view diagrams by entering your model number here:
Posted on Sep 22, 2007
I have a Kenmore microwave, model 721.62649200. The Handle to the door just broke off. I can find places online to buy a new handle, but I can't for the life of me figure out how to take the door...
I have a similar unit and I removed the outside of the door by loosening two flat head screws on the narrow where the handle is located. There are several screws yet holding the outside plastic housing too. Once these are removed the plastic door will come off. Then the handle will be accessible.
The same issue started with my oven too and I replaced the original handle with larger screws and using a high quality plastic glue.
This held for a while. The plastic door cover seemed to have changed dimensions during its life and warped. I ordered a new door and it lasted a short while. I then asked for a new door under warranty.
Bottom line they wouldn't sent a new cover but they returned my money. Apparently the doors all had crappy plastic issues. Currently we are using the microwave with out the door front. It still works like new after 10 years though.
Nov 12, 2012 | Kenmore 62622 Microwave Oven
Door handle broke off
bru the front internal cover snaps off. you need to stick a screw driver in the edges and pry it apart being very careful to not snap it or bend the outta metal frame undo the handles screws and replace as before but in reverse
good luck
Jul 12, 2010 | Hotpoint RVM1435 Microwave Oven
My samsung SMH7187STG microwave handle broke off.
You can order new "cap handles" (the plastic parts that join the aluminum handle to the door for 3.99 each plus 8.99 shipping and handling at the Sears Parts Direct Website. The part number is DE67-00222C. When you have the parts in hand, open the microwave oven door. On the inside surface of the door their is a black plastic frame around the door that pops off easily (gently use a screw driver to pry up the door frame) so that you can have access to the screws that attach the end caps to the door. You will need to hold the remant of the cap handle (the part that is probably broken off even with the glass surface on the outside side of the door) still while you unscrew the screws. Once the screws and broken remnant of the handle caps are out, you are ready to put new handle caps on the handle, then put the handle with the new handle caps on the door. By the way, Samsung was absolutely NO help with this. The agent I chatted with denied that their were any reports of the handles breaking off, so I had to cut and past the postings about the door handle breaking off ON THEIR OWN WEBSITE under "Community Q and A" into the chat box -- still the agent did not acknowldege the existance of these reports...or the possibility of a poor design. I asked for them to send me a couple of the $4 parts as a good will nothing but lofty words about Samsung commitment etc. and only a authorized technition blah blah, no action. All you need is a strong thumbnail, a phillips head screw driver, new handle caps.
May 02, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
Door Handle
If at all possible try getting an exploded image break down to see what needs to happen, basically you have two things in your way one is the "choke"...the large black rectangle on the inside of the door this has to be pryed off carefully all the way around and lifted off, pocket knife works great to get it started. next you will have the front door assembly snapped onto the mesh screen and frame of the door itself. Once you have seperated the front door you will see the screws for the handle, DONT OVERTIGHTEN these screws when you reinstall.
Hopefully this video clip
Aug 26, 2009 | Frigidaire FMV156EM Microwave Oven
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
I hope this helps you.
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
Handle broke and can't screw in the bottom screw of the new handle
bottom plate of the handle has a keyhole shape in the door-face of it
to go over a mushroom headed screw already secured in the door
tap the old broken handle down the door and it will pop off the screwhead
set the new handle sideways on the door, top end out into empty space, and pull it into place on the screw head,
rotate the handle top over the door and screw it into place, dont flex the handle much to twist it in place, they are brittle, and break
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Broken Handle
On almost any microwave oven door if you open the door,on the inside part of the door,theres a square plate thats plastic that is a one piece unit that goes all the way around the edge of the door . That held on by little plastic clips that are molded right on the suround and easy to break, so take a small screw driver(of course the ovens unplugged by now) and start at one end and start prying it out inch by inch. Being care full not to crack it. If yop do crack it, you must replace it, but its not that expensive. Once you have off the cover surround, you will see the screws that hold on the handle. If you need help getting the part go to as even if its not listed get the phone # and call them and they will assist you. Good Luck
Jun 03, 2006 | GE JVM1640 Microwave Oven
GE JVM1850 1000 Watts Microwave Oven Logo
125 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
