Question about Sony KV-32FS13 TV
No sound The picture is fine with the cable and the VCR plays but no sound. I get a low rushing noise when i turn the volume way up but nothing that goes with the screen. I checked and made sure the speakers are on in the menu and still nothing
  • 790 Answers
Check the amplifier section inside.. i think you have abnormal parts inside like small capacitors or change value.
Posted on Sep 06, 2007
When I play the vcr tape the picture is fine but no sound and the tv volume is turned up. Why?
you may have the vcr connected via a video cable from vcr av out to tv av in. If this is the case you should have an rca type audio out on the VCR and a audio in on the TV the plugs are Red and White color coded. THe video is usually yellow color coded. You may have an rf out on the vcr you need a tv cable from this to the TV antenna in port
if using this connection with a video cable instead of a 75 Ohm tv cable. the impedance is different and this could be another cause of your problem. The cables look identical but are different electrically.
Oct 13, 2014 | Televison & Video
Vcr wont play
Loudness or volume is controlled by the amplifying device to which your VCR is connected.
Nov 27, 2017 | Audio Players & Recorders
Have no sound from VCR, cable hooked up properly, picture is great. TV is brand new.
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
Aug 12, 2010 | Toshiba M755 VCR
Older TV works great alone including sound. Cable TV but no box. VCR connected with cables (red,white and yellow)to TV and has worked fine. Playing home recorded VCR tape picture OK but sound is low and...
Very likely the VCR audio head is dirty which will give you muffled or low sound on play. Remove the the top cover & using a piece of non-abrasive cleaning cloth & a head cleaning fluid gently rub the audio head to clean it. The audio stack sits to the right hand side of the deck, it is usually a siler block which will be placed in front of a black roller. The head is on the side of the stack facing toward you, give this area a wipe, try a fresh recording & then replay the new recording to see if the sound has improved.
Aug 16, 2009 | Memorex Televison & Video
Crackling noise on sound system
This could be a defunct sound driver when it saw the sound speakers. Go to the device manager and go to the multimedia controller and delete it. Restart the machine, it should call for the correct drivers. If it says cannot find drivers, go to www.driversguide.com, sign up, then query for the correct drivers for your sound
Jun 17, 2009 | Panasonic Home Theater System System
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Video noise
if the picture output from your system goes through your vcr to get to your tv that could be the problem. try connecting it directly to your tv
Dec 27, 2007 | Sony DAVHDX265 System
Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Aug 18, 2007 | Bose 3 2 1 GSX System
Sony KV-32FS13 TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
