Question about KitchenAid Architect Series KEBC208KSS Electric Double Oven
Kitchenaid double oven shut down!
I have a double oven. i tried to self clean it. basically i closed the doors and pushed the clean button. it seemed to be working fine and then all of a sudden the the whole thing just shut down. none of the buttons are lit up. i cant do anything. the door remains locked. i thought it was the circuit breaker. i replaced the breaker and that wasnt it. there is electricity going to the oven, but nothing is happening. please help. this is only 2 years old!!!!! thanks in advance for all your help
  • 6 more comments
  • Anonymous Dec 04, 2007
    Same problem with the self cleaning/fuse blown problem
  • chev55 Jan 05, 2008
    kebc208kss
  • Anonymous Apr 01, 2008
    We have KEBC207KBL0 17 mos. old first trouble 6 mos ago.First attempt to clean upper oven shut the operation down on the lower oven. It has not worked since. Repair people have guessed at trouble and changed 2 control panels and now have ordered a wiring harness. We have had error messages E1 and F5 since the first evidence of trouble.
  • harleyd182 Apr 25, 2008
    I have the exact same problem. Pushed clean and left it for the night. Got up in the morning and seemed to have no power to either unit. Checked circuit breaker and nothing was bad at the breaker box. Looking for solutions right now.
  • Anonymous Jun 10, 2008
    over door will not open. this happened after i started the cleaning cycle.
  • Kurt V Nov 14, 2008
    Same problem.  I've replaced the upper oven thermal fuse, but the oven still won't turn-on.  There's power to the oven and I believe power to the LCD panel.   After two Kitchenaid dishwashers, I've finally gone to Bosch.  Perhaps it also time to move away from Kitchenaid products all together.
  • meganomearal Feb 14, 2009
    My Kitchen Aid double oven just shut down, the only thing that turns on is the interior light. I read the the best solution, do I just get fuse links at the harware store? I understand it is a two person job but do I need an oven repair person or is it simple?
  • Anonymous Apr 20, 2009
    i had the same problem ,however Oct05,2007 guest , nailed it on the head. i replaced the thermal fuse and everything is back and working!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Posted on Oct 05, 2007
SOURCE:
My kitchenaid superba double oven in not woring at all after the self clean cycle finished. top oven door will not open, no lights on, nothing happens when I push buttons
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 22, 2010 | KitchenAid KEBC107 Electric Single Oven
(1)Cannot find location of model number. (2)Cannot locate service manual. (3)Need to clean oven. I believe the ovens (double/wall/electric) were installed in, or around, 2003, 2004. Simple want to know the...
need to know what model and brand you have.
most newer ovens only need you to remove the racks, then push the button for self clean, push the button to allow about a 3 hour clean cycle and it should then go into a lock the door mode. after the time is up it will need to cool down and then you should be able to open the latch and wipe out any burnt residues.
Dec 31, 2009 | Ovens
Thermador sc302tctop selfcleaning oven will not go on. Looks like
try holding the door in just abit when trying self clean
from the sounds of it you having issues with you hinges
it might no be able to grab the door and pull it in
there by cancelling the clean
Oct 09, 2009 | Thermador SC302T Electric Double Oven
My oven door is locked shut. I think it was not closed completely when I programmed it to self clean. The information pad alarmed "door" and I tried to push it closed but it will not close, open or...
heatman101
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven shut down during self clean. Door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Aug 21, 2009 | DCS (WOTD-227) Double Oven
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
KitchenAid Architect Series KEBC208KSS Electric Double Oven Logo
572 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Craig Butler
Craig Butler
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
