SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
SOURCE: kenwood KD-491F belt come off How do I put it
You have got to lift the table on which the vinyl is placed underneath you will find the belt laying loose on the bottom of the table is a pulley on you fit the belt then on the right hand side or rear is the pulley on the motor which the belt also has to be fitted then carefully lower the so as not to let the belt come off again this should provided the belt is not stretched or snapped then it will have to be reaplaced
Testimonial: "Great thank you, know I know the belt has stretched, so I will have to buy a new one. 10/10"
