Question about Toshiba RD-XS32 DVD Recorder
Not copying program
Inconsistent copying of recorded programs. Says disc is defective. Identical unit copies each time on same discs.
  • 3 Answers
I updated my firmware from 1413 to 1416 found on avforums. This is for european units. I suggest you also complain to Toshiba Japan as there are known issues with the xs32. We all need a firmware update. See AVforums.
My unit will not recognise RAM discs anymore - even those that I had previously used.
Have you thought of replacing the DVD drive. See AVforums.
Posted on Jan 09, 2008
SOURCE:
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
I cannot copy commercially recorded VHS tapes to DVD. Msg comes up saying it is COPY PROTECTED. Heard that if for personal use only I am permitted to copy tapes. Any way around this?
No,this can be done only copyright materials through the VHS box converter run through a computer with a programs call copy decoders programs.Than u can copy VHS copy protected matrials.Than u reburn it back to DVD disc.So this require alot of work,time and money so not worth it to copy commercially VHS tapes to DVD Disc.
Jan 19, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
Tells me i cannot copy a copy protected program
correct, if you are trying to copy an origional disc, that is a pre-recorded disc, then the copy right protection kicks in. If you are trying to copy a recorded disc, it may be the wrong format for the player.
May 22, 2010 | Samsung DVD-VR357
This program is not recordable in +vr mode, this is the error message, i am trying to put my programs that are saved on my comcast dvr onto disc, the manual says these are "copy-once" programs, what does...
This means exactly that these are copy Once only, meaning you can not make it copy say 10 copies, at the same time, it means you must do one a at a time. If you wanted say 10 copies, you must do the entire process over and over.
Apr 02, 2010 | Toshiba DVD Recorder
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
RCA CDRW 140 dual deck CD recorder
READY
Place cd you want to copy in tray A (EVEN WHEN YOU WANT TO GET ONE SONG COPIED )
Blank Disc in tray B .
Program tacks in any desired sequence
Press the TIME SET / PROGRAM button on recorder or remote..."WAIT" appears then "01" flashes to let you know the unit is ready for the first track.
Enter the first track you want to program using the numbers buttons on the remote .
or SKIP / SEARCH button on recorder.
When the track flashes PRESS TIME SET / PROGRAM on remote or recorder.
to select it , "OK " appears
HOPE THIS IS HELP YOU NEED >> GOOD LUCK
I WISH MINE WOULD WORK IS DOWN AND OUT !
Oct 08, 2008 | RCA CDRW120 2-Disc CD Recorder
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. [email protected]
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
Unsupported discs
Hi there
I think your DVD Player could have been damaged while it was in storage, this sounds like there is a problem with the lens (laser), i am going to suggest that you take it to a repairman and ask him to fix it or buy a new laser for your DVD Player attempt to fix it yourself.
If your DVD player is still under warranty, you should take it back to the retailer and have it repaired or refunded.
This could also be caused by "un-married" Player and Disc, if you bought the DVD Player in one country and bought the DVD's in a different country, this could also cause the problem. If the DVD's are copied, that could also cause it.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 5692f33.png if it helped you.
Kind regards
Dustin Ellse(BearWeb)
Jul 03, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Toshiba RD-XS32 DVD Recorder Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
