Question about Car Audio & Video
Car battery my car battery failed so i replace it with another one,the same problems still occurs when i start its ok then once i turned it off after few minutes it dead again no power at all...any tips?
  • 752 Answers
Your description is missing some detail but it sounds like your alternator is damaged. Take your car to a service center to have it tested.
Posted on Sep 08, 2007
My car will start but after about 15-20 minutes of driving, the car will completly turn off...i have to wait for the car to cool down for about 30 minutes before i can restart again and drive it.. If i...
if light on dash is on, then it sounds like a bad crank sensor. shuts off while driving down road, then will not start for about 15 minutes. heres more causes:: car shuts off when tempurature gets to normal-- low coolant, failing coolant tempurature sensor, air in water pump, failed radiator fan, it takes 10 to 15 minutes for a car to warm up. check or replace coolant temp. sensor if above is ok. have a good day !
May 04, 2011 | 1995 Geo Prizm
Ford probe 24v sport engine, starts ok cold, but after a few minutes warming up it cuts out, leave it for a few minutes and it starts and runs no problems, just the cutting out bit thats a problem
Hi and welcome to FixYa!
Mostly this is caused by a failing coil pack. It is located on the side of the engine where the spark plug wires are attached. You will need to remove the cap to gain access to the coil pack. Once replaced you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 27, 2011 | Ford Probe Cars & Trucks
OMG!! its a nightmare! Help!! i turned my navigator this morning and the battery light stayed on the dash board...when i accelerate it either blinks or goes off for a few and it comes back on...i had put a...
Yes. There is a very good possibility that your alternator is beginning to fail. The battery only starts the car and maintains nominal accessories. The alternator on the other hand actually provides the fire/spark for the engine after it has started o keep the engine running.
The light coming on and off is indicating the alternator is failing or falling below what is needed for the engine. When this occurs the system defaults to the battery, where it drains the battery. At higher speeds/RPM's the battery light is probably turning off - right?
A very easy way to check this is to start the vehicle, and with the engine running, remove the Negative (black) Cable going to the Battery. If the engine dies, it is the alternator and needs to be replaced immediately. Once an alternator fails, it will drain and kill the battery.
Jan 28, 2010 | 2001 Lincoln Navigator
1991 Honda Accord won't start. Battery seems ok
Sounds like the distributor. But you may have a faulty replacement coil..get an exchange and see if it is faulty. I have received many replacement parts that fail prematurely.
Oct 14, 2009 | 1991 Honda Accord
Power problems
1. Change your fuel pump.
2. Have a look at the starter. That is definately the problem.
Cheers.
Rate this solution.
Apr 20, 2009 | 1990 Toyota 4Runner
Sometimes the engine doesn't start and the spark plugs are wet
Change cap & plug wires. If emergency before wire & cap repalcement, spray wires & cap with WD-40, let sit a few minutes & try it. WD-40 displaces moisture. Don't keep doing that though, its dangerous, just replace wires & cap.
Jan 22, 2009 | 2000 Honda Accord
1993 Honda Accord-shuts off while driving/won't start up
I had the same problem. My car would shut off without any warning, I changed my Main Relay located under the dash, right below the change slot on the left hand side. I have not had a problem since. The price at Napa Auto parts runs about $68.00. This should fix your problem.
Oct 08, 2008 | 1993 Honda Accord
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Car Audio & Video Logo
323 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
