Question about Toshiba 42H81 42" Rear Projection Television
No red color in picture
I have a (42H81)42 inch Toshiba rear projection TV and there is no color red in the picture.
  • cindyprobst Dec 24, 2007
    I have the same problem too! Can somebody help me??? My TV is only about 8 years old. HELP PLEASE!?? CINDY CELL: 214-882-2626
    [email protected]
    President:
  • 4,402 Answers
Red tube bad.
Posted on Dec 05, 2007
SOURCE:
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV picture is red.
Normal color picture is composed with 3 colors R-G-B (Red-Green-Blue). Picture turns Red means: Missing Green and Blue colors (many reasons: bad contacts, projector tubes dead, and other...). Try to give some "tabs" to diagnose ... I don't know what is the type of your Projection TV, how long you owned it, to have more idea.
May 15, 2009 | Toshiba 57H81 57" Rear Projection...
5 year old RCA 50 inch projection tv. Picture went off.
If you are using component cables make sure they are all connected properly( pushed all the way in and in the correct input). I have seen the red cable come loose several times and cause no red color in the picture. When you change the lamp it is easy to pull on one of those cables and cause it to come loose.
Jan 30, 2009 | Toshiba 50H72 50" Rear Projection...
Toshiba 55H70 COLOR PROBLEMS
turn your red screen voltage down till you get grey, your convergence out puts will need replacing
also the limiting resistors usually a low resistance, cheers parts from global look for stk -*.*
Oct 08, 2008 | Toshiba 55H70 55" Rear Projection...
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 65NH84
You might have burned out the red color crt. In projection TV's there are 3 CRT's (one for blue one for red, and one for green). If you have the other 2 colors but no red I would assume this is your problem. You should be able to get it fixed for around $150.
Jan 13, 2008 | Toshiba 65HX81 65" Rear Projection...
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
