Question about RCA D56W20 56" Rear Projection Television
Tv cuts off and on.
When the tv is put on it stays for about 5 mins then cuts off. the front power button light then begins to blink. i have to take the power cord off for about 2 mins then put it back on.it then comes on and may stay on for a longer time or may cut off again.
  • homer33 Jul 08, 2008
    My tv will run for awhile then shut off then turn on by itself. If I put a fan behind it it stays on longer. It's like it gets warm and shuts off. Is there a cooling fan in the back that could be bad?
  • 29 Answers
Sounds like a bad SSB(small signal board) module. Better take it to a RCA AUTHORIZED service center.
Posted on Sep 08, 2007
Panasonic 60" LCD Projection TV Turns off every 1-2 hours
What is the model# of your TV?
Do you see any blinking (LED) lights on the front of the TV?
How many blinks?
Which LED light is blinking, Power, timer or lamp?
Nour Sabre
www.aaatvservice.com
Nov 15, 2011 | Panasonic Televison & Video
When I turn the tv on it stays on for a few seconds, and then cuts off
is the power light or lamp light blinks? if its the lamp then replace it. your tv lamp model # XL-2400. check this link https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=600259&searchOperation=modelSearch&searchText=KDFE42A10
or if its the power light that blinks then turn off tv for 5 mins. unplug power cord for 1 min. try plugging the power cord directly into working wall outlet. if same, tv needs service. visit eservice.sony.com website to check service option
Dec 24, 2010 | Sony KDF-E42A10 42 in. LCD Television
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
The tv just turns off after about 5 seconds and won't stay on. i've used the system reset and unplugged it already. no power surge, lightning storm, etc. Ideas?
If reset does not cure it and if after about 70 seconds of unplugging set the green power light stops blinking, do this:
When power light comes on and goes off, on the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and RELEASE both buttons.
Power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code you find and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Sentry RMC-10 remote can't 'discover' my tv's code
.there are several codes. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES:1171,0116,0167,0176,0922
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Sentry SE-RMC10 Remote Control
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
RCA D56W20 56" Rear Projection Television Logo
112 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
