Question about 2wire HomePortal 1800HG Router (1000400229000)
Email problems with a WiFi network using a BT 2wire 2700HG
I have setup 5 PCs on an office wireless network via a BT 2wire 2700HG gateway router (downgrade from a Win Server 2003 server/network) and Emailing send and receive do not work (using Outlook Express) but I know that the email setup is OK because I have the same setup on my laptop and I can send and receive when I am out of the office using a different wireless network AOL)? The Email uses a third party to collect the incoming emails POP3 (name.co.uk) but the sending is still smtp.btconnect.com. Could the problem be the Firewall on the 2wire 2700 or is there some other explanation? Any help would be appreciated! Regards Gerryw01
  • Gerard Walsh
    Gerard Walsh Sep 08, 2007
    The solution guided me to get within a wisker of having trouble free emailing.
    All I had to do after following Sandrews guidance was to set the email address to name.domain.co.uk and leave the reply address blank and Hey Presto worked like a dream!
    Thanks Sandrew
    Gerryw
    President:
  • 2,961 Answers
Because you have a third party email account you will have to go into the email accounts and in options look for my outgoing server requires authentication and tick the box. You may also need autorization from bt as they may not allow the incoming emails. also check that any antivirus programmes arent stopping the outgoing mail and putting them in the outbox.
Posted on Sep 06, 2007
SOURCE:
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
Cannot get a 2Wire Gateway to recognize linksys wireless print server (wps54gu2). Can set up using lan and fix IP, enter wep password, etc. Once disconnected, gateway doesn't even recognize device.
1. Need to know what OS ( operating system) you are using.
2. Have you check if the settings are on " automatic DHCP and do you have the router
3.Check the firewall settings. This disconnection if not on the "access list" in the firewall settings.
4. Make sure you have the most current firmware updates on the router.
5. See if you can "ping" the wireless router.
6. check the " up grade history" page.
Apr 19, 2010 | 2wire 2700HG-B Router (2700HGB)
Fry's wireless g router
I found this on this site:
2Wire 2700HG-B Setup
1. Connection of phone line, ethernet and power adapter
2. Indicator light: POWER: green; Ethernet: blink; DSL: green; Internet: blink or red
3. Open IE beoswer.
4. address: 192.168.1.254
5. Click "Run System Setup Wizard"
6. Login with preset password: admin. Or change password: click "I forgot the password." Under question "Here’s a hint for the password wedding date", click "I still can’t remember the password.". Then Reset System Password by enter System Key which locate on back of the Router (like: [1234567890]), and your new password, then click "Submit"
7."Set Up Your 2700HG-B Gateway" screen. Keep default "Key Code". Click "Next"
8. "Time Zone". Select your time zone,then click "NEXT"
9. "Set Up Connection Info". Enter "PPP Authentication" information provided by internet service provider. "Username", "Password", and "Confirm Password", then click "NEXT"
10. Screen "Connecting" running...
11. Auto turn to screen "2700HG-B Gateway Setup Complete", click "FINISH", or "EXIT" to complete setup or "Register" to register with 2WIRE on line.
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
CAN I USE A WPA2 SECURITY WITH THE 2701 2WIRE B-ROUTER
It only supports WPA and WEP. If you need help setting it up, here is a great guide: http://server-servers.com/att-dsl-2wire-2700hg-b-router-setup/
Good luck
Dec 28, 2009 | 2wire 2700HG-B Router (2700HGB)
I am using a 2wire wireless router with modem and am trying to hook up 2 pcs to the local area ports. I can't get a connection on the local networks but can on the wireless. I've tried a few different...
start by pinging the gateway. if you get a reply then the connection is good.
next try a nslookup at the command line.
the syntax is nslookup google.com
you should get back an answer like:
Non-authoritative answer:
Addresses: 74.125.67.100, 74.125.127.100, 74.125.45.100
If not it then it is a DNS problem not a connection problem. Make sure you have the DNS servers setup in your network configuration.
Sep 20, 2009 | 2wire 2700HG-B Router (2700HGB)
No connection to laptop.
I would imagine that you have the desktop wired to the 2wire router... Does the desktop have a static or dynamic IP? If you want it to be dynamic you will have to setup DHCP on the router to give the laptop an IP address... Otherwise set the IP on the laptop to the same subnet that the desktop and router are on, i.e 192.168.1.0... Make sure that the laptop is has a static (doesnt change) IP or its setup to receive an IP from the router or another DHCP server, if you have a DHCP server on your network... To make the laptop a DHCP client, set the wireless NIC to automatically select an IP and automatically select DNS servers, this can be done thru the control panel>network connections, then select your wireless NIC, right-click on it and select properties, on the first page of the properties menu, highlight TCP/IP then click on the properties button and when that screen appears, select the radio button for automatic selection of IP and DNS... if you will not be using dynamic IP/DHCP, you will manually have to enter the IP address, subnet mask, default gateway and DNS server IPs.... Let me know if this helps or if I can clearify something for you! Best of luck!
--Joshua79
Apr 02, 2009 | 2wire 2700HG-B Router (2700HGB)
Connection to my computer of hp photosmart c6300 via belkin adsl2router
3. Open IE beoswer.
Oct 30, 2008 | 2wire 2700HG-B Router (2700HGB)
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
D-Link DP 311U wireless setup
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Feb 09, 2008 | D-Link DP 311U (DP-311U) Print Server
Computers & Internet Logo
639 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
