I have an 02 Alero with factory monsoon system and h/u. I have installed an amplifier and 2 subs. I am running the main power from the battery and ground to chassis. I have purchased and installed the necessary 1k line converters and fed them from the rear deck speakers to the amp inputs. I have managed to power up the amp successfully but with a loud popping noise due to using an "accessory on" power supply from the fuse panel for my remote on. That is the first noise. Secondly, even with the volume of the h/u at 0, the amp will start to power up and as it does the subs start vibrating and going wooowooowoooo louder and louder until I disconnect the remote wire to shut the amp off. I am unable to use and power it up due to this vibration. Is there a simple solution?
SOURCE: low level noise causing sub flutter
Power wires and sound cables running close together can cause this problem. Separate them.
Posted on Dec 09, 2007
SOURCE: I have hooked up my subwoofer and amp to my
Rewire your stereo cables as such:
Red- positive - battery
Black - ground - chassis
Remote (Yellow) - ignition switch
The "LINE OUT" should go to your SUB-WOOFER.
The while-lined wires paired with the solid colored wires are either your Front LR and/or Rear L/R.
Posted on Jun 14, 2010
Dec 20, 2011 | Audio Players & Recorders
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
Mar 07, 2010 | Kicker CVR12 Car Subwoofer
Dec 12, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
Aug 04, 2009 | Sunfire True Sub MK II Subwoofer
Feb 12, 2009 | Alpine IDA-X300 Car CD/ MP3 Player
Jan 26, 2009 | 2002 Pontiac Grand Am
Mar 04, 2008 | Audio Players & Recorders
the ground may not be coming from your stereo it should be coming from a loose wire under the hood. Do u have the factory radio? that might be it if u do
Sep 09, 2007 | Car Audio & Video
Sep 05, 2006 | AudioBahn A8002T Car Audio Amplifier
Apr 23, 2018 | Car Audio & Video
151 people viewed this question
