Question about Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
My heating element is out and my dryer won't heat up. Does anyone know where to get parts and a schematic for the WD1000? There is no Malber service person in my area. Thanks.
  • Anonymous Dec 12, 2007
    I need a drum drive pulley for malber wd 1000.I tried any online site any phone number and noboby have hured of this wahser
  • Anonymous May 15, 2008
    i need a heat element for my malber wd 1000 where can i find help me
They are located in ny tele 516 294 6660 malber
Posted on Dec 16, 2007
  • 625 Answers
Check two places. repair clinic dot com and parts select dot com
Posted on Sep 07, 2007
Hwant schematic for Maytag dryer model YMEDE301YGO
Go to Partselect.com. they will ask for model number and serial number of your dryer. They have every single little part for appliances but better yet they have video's on how to make the repairs. They also have schematics for every conceivable appliance made. the prices are very reasonable and the customer service is top notch!
Mar 05, 2015 | Maytag Dryers
I have a Servis M9409S washer dryer. The dryer isn't heating up at all, and I'm assuming it's the heating element. Does anyone know how to replace it?
There is only one place that I can find that part: http://www.partmaster.co.uk/servis/m9409/element/catalogue.pl?path=66991,61187:66997&model_ref=29129&refine=element
Jun 05, 2014 | Dryers
Schematic kenmore 110 96585200
Firstly, take off the vent that hook up to the rear of the dryer, if the dryer got heat again. You should clean the vent. Else, there are quite a few component caused no heat. They are: thermal-cut-off (non-resettable), heating element.
Beware to unplug your dryer before opening it. The cut off thermal and heating element can check it connectivity by ohm meter. Normally, the cut-off causes this issue.
Check this link for more information http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11096585200/0582/0151200/10036890/00003
Oct 15, 2013 | Dryers
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 31, 2012 | Dryers
Daryer is not heating
The heating circuit of the electric dryer consist of the following parts. The timer, the heating element, the hi-limit thermostat, the safety thermostat, the operating thermostat, the temperature switch and the motor centrifugal switch.
If any of these parts fail, the dryer will not heat. Now, most people when the dryer stops heating, replace the heating element or the timer with out checking to make sure that those parts are bad. Rule number one is, don't assume that the part is bad with out checking it with a multimeter.
The first and most important thing you need to do, is to disconnect the dryer from the wall outlet before doing any kind of work on it. Most parts will need to be checked for continuity and the dryer must be disconnected from the wall outlet.
Most of the times the part causing the problem is behind the dryer and you can gain access by removing the back panel.
Remove the back panel on the dryer. Disconnect one of the heating element wires and take a reading between the two terminals on the heating element. The reading should be between 10 and 50 ohms. If the heating element is good, check the hi-limit thermostat by removing one of the wires and checking for continuity. Continuity means, that electricity could pass through the part that you are checking.
The hi-limit usually blows when there is an obstruction on the exhaust hose, so make sure that the exhaust hose is not obstructed when replacing the hi-limit kit.
If the hi-limit thermostat and the heating element are ok, check the operating thermostat. The operating thermostat is in charge of maintaining the temperature inside of the drum at about 150 degrees. You will need to check from the two terminals with the red wires attached on it.
Those where the parts that fail more often in the Whirlpool electric dryer. The timer, the motor centrifugal switch, the temperature switch are a little harder to check because there are may different one. You will need to use your wiring schematic to see how to check them.
Aug 17, 2010 | Frigidaire GLER341A Electric Dryer
Not blowing hot air element ok, need schematic
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 17, 2010 | Dryers
I have a Kenmoe dryer, model #110.62512101. it does not heat.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Click here to be directed to the parts list and diagram page.
Sep 14, 2009 | Kenmore Dryers
No longer heats during dry
HELLO THERE:
if you have cleaned all of the lint from the filter and still no luck you are goiong to be looking at replacing the heating element.
contact your local appliance repair for this part and a price ok?
best regards mike
Aug 09, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
492 people viewed this question
Top Malber Washing Machines Experts
Jason Harris
Jason Harris
Marvin
Marvin
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
