Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
I changed the bag and my vacuum won't turn on!!!
I changed the bag and the air filter on my Electrolux Vacuum but the red light is still on stating that the bag needs to be changed. I have tried every way possible to put the new bag in but the red light still remains on. I don't know if there a restart button or something else I am not doing.
  • Anonymous Dec 08, 2007
    I changed the bag and the question mark ? won't go off and vacuum won't start
  • Anonymous Jan 06, 2008
    I am having the same problem, but I take off the hose and it works without that, so I am thinking that something is clogging the hose. I have tried many things to "unclog" it but am not having success.
  • 75 Answers
Try vacuuming the inside of the tank out, and see if that helps clear off the sensors.... If not call (570)326-1731 and ask for Liz adn I will be happy to try and help you aout.
Posted on Jan 14, 2008
  • 625 Answers
Open up the bag compartment, remove the bag. look in the lower right side or upper right side, you'll see a hole - make sure it is cleaned out no lint inside. this is a part of the differential system that stops the machine.
Posted on Sep 07, 2007
What does it mean when my electrolux 2100 vacuum's protection light is on and the vacumm won't start
hellllllllo.......in short....youtube....."is your electrolux not turning on" [a] bag sensor [b]carbon build up............tkx....g.scott
Sep 25, 2014 | Vacuums
How do I change the air filter
the top of the vacuum where the tools go comes off,the filter goes underneath..Chris
Jun 25, 2014 | Electrolux Guardian Bagged Canister Vacuum
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have an older model Electrolux canister vacuum and it turns off quickly after turning on and this checkered light comes on. It happened right after i finished cleaning the ashes in my stove which i...
Make sure there is no obstruction anywhere along the hose. Also properly clean the filter and collection bag. This may have become blocked due to the fine ash, sort of sealing the bag.
Jan 02, 2018 | Electrolux Guardian Bagged Canister Vacuum
The vacuum won't turn on. plugged in, all lights flashing. no power
When switched on the vacuum goes through a self diagnosis test. Lights will come on for a while, then go out. If everything is okay, then the blue "Optimum" light will come on and stay on. If it turns of, a red indicator light should come on providing information on what's needed; i.e., filter or bag change needed.
Aug 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Oct 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
244 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
