Question about Kenmore 54701 Dehumidifier
The dehumidifier is blow cold air
Before when I turn on the dehumidifier it blow hot air now when I trun on the power it start blow cold air
  • 11 Answers
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Posted on May 29, 2009
    New Friend:
I've just recently experienced the same problem with our dehumidifier. It's now blowing cold air and no longer collecting water. I'm assuming the heating element has failed. I'll post again to confirm whether replacing this part fixes the issue.
Posted on Feb 08, 2015
  • Dan Riley
    Dan Riley Apr 25, 2016
    A bit of a delay in posting back, but I can confirm that replacing the heating element was the right fix for me. Upon inspecting the old one once removed, you could see some of the veins had corroded and broken.
SOURCE:
Why is it blowing cold air?
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Jan 15, 2016 | Amcor Dehumidifiers
My frigidaire dehumidifier isn't not dehumidifying .is the warranty still good
Good Morning Friend,
I understand your Frigidaire dehumidifier, model# LAD704TDL, is not dehumidifying. I also see that it is blowing hot air, no water is coming out of the hose, and the humidity stays at 80%. I suggest contacting the manufacturer directly, to see if your appliance is in warranty, and they should be able to point you in the right direction. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire Dehumidifier LAD704TDL
Fan barely turns
If the fan is barely turning, it could be the fan is bad. This fan blows air across a 2 coils.
May 29, 2014 | Haier HD456 Dehumidifier
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
My dehumidier blows very hot air while working. Makes it hotter than it was before starting. Like a furnace.
It is normal for a dehumidifier to discharge warm air. A dehumidifier is really an air conditioner - a fan blows humid room air across a cold fin coil that causes the moisture to condense on it and drip into a container - thus cooling AND dehumidifying the air. The cool air is blown over the warm coil and discharged out the back. A dehumidifier WILL normally increase the temperature of the room it is in.
You can do the same thing with sitting an A/C unit on a stool in a room. Room air will be drawn in, cold air will come out the front, hot air out the back and water will drip on the floor. And, the room will get hotter, due to what is called "heat of compression" even though you're running an A/C unit.
Jun 26, 2013 | Windchaser WDH928 Dehumidifier
Dehumidifier,lot of hot air blowing from the rear panel not much from the front
I suspect that the dehumidifier coil, the section that gets cold, is clogged up with dust or dirt and this is why it is not working properly. Do not continue to run it this way or you could burn up the compressor!
Jul 21, 2010 | Whirlpool AD50USL Dehumidifier
Dehumidifier headaches!
There are three things that must be working to extract water. The 'coil' (a finned metal part that allows air passage) if it's filled with dust and obstructions, no air can move...no water. There is a blower motor that mus move the air. If it is seized up an not blowing air...very little or no water. The compressor uses condensation from the air moving across its coils (like the moisture than forms on a cold glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 27, 2009 | Kenmore 54501 Dehumidifier
Dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
30 pint model # M30H3082A
A common problem - low on refrigerant. Unfortunately it's not a simple fix. Check your warranty to see if you're still covered for "Sealed system repairs"
Nov 30, 2007 | Kenmore 54501 Dehumidifier
Kenmore 54701 Dehumidifier Logo
7,262 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
