Question about Archos AV 500 400-Hours Video Recorder
AV 500 "No input signal" on multiple attempts
My AV 500 will always inform me that there is no input signal, even on video sent from every conceivable source I can find. I've tried every set up; auto, B and W, and component. I have two cables and they both play video from the unit to a tv (cable is okay)...alas, no input signal Anybody.... Did I miss something...
Make sure your power source is connected to the dvr docking pod
Posted on Dec 05, 2007
    Genius:
  • 1,139 Answers
Check to make sure all of the configuration on the AV 500 are as they should be. If they are you are looking at a defective unit (might be hardware based) if it is I would suggest that is you do not have a background in electronics to take the unit to a repair shop. If you do have experience you will need the following items: A schematic diagram of the AV 500 A Multimeter to measure the voltages at test points of the AV 500 An Oscilloscope to measure the signals and levels at test points of the AV 500 if you have these pieces of equipment then you will want to start your test at the dectector stage (this is where video and audio are separated from the IF which is derivied from the RF so if you have video and audio at this point you know the input RF-IF-detector stages are working. Now based on your troubleshooting you inputted signal at the video processor by using the the video inputs, so from this I am going to take a stab at saying the problem more then likely would be located in the stages at and after the video processor stage (since in this case no signal may mean no video signal as opposed to no RF signal).
Posted on Oct 08, 2007
6ya staff
SOURCE:
AWA Tv wont allow the AV source to load. constantly says no signal.
Scan through the AV input source selections on the remote until you find the right input
Jul 03, 2018 | Nintendo Video Game Consoles & Games
How do I select AV input
Older tv sets tend to have at least one button on the remote to select the AV input but more modern sets the function is automatic - switching to AV when a signal is received via the scart socket, etc.
Sep 11, 2017 | Televison & Video
I got a Samsung 1080i television, but when i connect my dvd player to the back, it does not pick it up. i also tried connecting a tv freeway antenna and that did not work either.
Check the input selector. If it is not set to use the source signal type, the set won't pickuup any signal. If the source signal is antenna, you shoud select antenna as input selector. If the source signal is AV, you shoud select AV in the input selection. Press the input button at the remote controller, and do the needy.
May 31, 2017 | Samsung Televison & Video
Ps3 plays in black and white with av composite cable
Some newer TVs do not have the traditional "yellow" video input, known as an "AV" connection. Even without that input, you should be able to use the standard three-color Wii AV Cable that came with the system.
What to Do:
  1. Look for "component" inputs on your TV. These connections have a row of five differently-colored inputs (green, blue, and red for video, white and red for audio). If you have more than one set of component inputs, it's the first set that generally works with standard AV cables. Look for a set that has a green input with yellow around it, or the word "video" just above or below it.
  2. Plug the yellow end of the Wii A/V cable into this green "Y" input. Plug the white end into the audio "L" and the red into the audio "R." Leave the blue and second red holes open.
  4. Turn on your Wii console and set your television to the input select being used.
  5. If you are seeing the image from the Wii in black and white, try the following to get the image in color:
    • Cycle through your television's input channels (usually with the "Input Select" or "Source" button on your TV's remote control) to find the input select that has the image in color.
    • If you're only finding the image in black and white, you may need to switch the setting of the input select from a component signal to a standard AV signal. This can be done by:
      • An on screen menu option. This is often accessed by using the "Menu" button on the remote.
      • A button on the remote that switches between the standard and component signals. These can be labeled such things as "AV" or "Video."
Jan 28, 2018 | Haier HL22R 22 in. LCD TV
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
I have 21 GOODMANS LD2212 TVs and want to play an MP3 player through the "audio in" however it shows no AV signal (yes I have selected AV or SCART source) likewise if I use a scart and connect...
From your description, it seems like the set doesn't activate the AV input unless it sees a video signal. I don't know if it the input is smart enough to require a valid composite signal (that is, one from a source that includes proper synchronizing signals) or if it will work as long as something is there. So here's a suggestion. Get an RCA Y-adapter with one jack in and two plugs out, and split one of the audio outputs from the MP3 player. Feed the audio to the audio input as normal, and connect the other plug to the video input. This may enable the AV input since there will then be some signal at the video input. It won't be a valid video signal, of course, so if it works you'll just see random flashing on the screen. Maybe you can pretend it's a light show to accompany the music.
Mar 30, 2011 | Goodmans Televison & Video
Where do i find thr AV setting on my tv set?
If you mean changing the input source to AV, it depends on the brand and model. Some units have an Input or Source button on the front panel (or side panel) of the TV and on the original remote. Other models only have this button on the remote.
If you are interested in a replacement remote for a unit that only has the Input button on the remote, try a searching for the model on remotes.com . Alternatively, look for a universal remote that is newer than the TV with an Input or Source button. Then try all the codes for the brand until you find the one that makes all of the features of the remote work.
If you are interested in the signal information (resolution, for example) of the content on the AV source, try the Info button on the remote (if available). To adjust the setting enter the Menu (either from the button on the remote or the TV panel (if available) and look for the Picture submenu.
I hope this helps. If you provide the make and model of the TV, I may be able to provide more information.
Mar 21, 2011 | Televison & Video
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
Foot note to issue
If the source to the PIP input is a color signal then the PIP display will be color. PIP sets have two video sources one goes to the main screen while the other goes to the PIP. it all depends on what the format of the signal is being sent to each input. This is quite normal.
Jun 29, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Archos AV 500 400-Hours Video Recorder Logo
250 people viewed this question
Top Archos Televison & Video Experts
Inky Fingers
Inky Fingers
Jaime Hernandez
Steve Sweetleaf
Steve Sweetleaf
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
