Sony Cyber-shot DSC-W50 Digital Camera
Problem for Sony Cyber-shot DSC-W50 Digital Camera
Access Probelm with DSC-W50 camera
By Andrew T on Sep 06, 2007
I receive "access" error when I turn on my camera. The lens continually tries to open and close. This repeats until I get a message: to power off and restart again. I tried that many times with no success. I change my battery with no success. I changed my memory stick also without any success.
I have tried to do a reset, however I cannot get access to any function keys to begin the reset function
My daughter had same problem with her Cyber-shot several years ago too, but her camera was unfixable. Is there any way to diagnose this problem. I dont want to spend about $75 to have a Sony authorized dealer tell me that the camera is not fixable (of course the camera fell out of warranty about 5 or 6 months ago).
I have also heard that this situation is fixable if you take the camera cover off. Is this true?
Thanks.
Same Problem
May 21, 2009
-   I didn't believe the smacking would work.....but low and behold I gave it a few hard taps on the table and......whalah, working again!!!!!! Thanks for the simple fix.-   Guest
May 12, 2009
-   posted by Andrew T on Sep 06, 2007
Thanks.-   NAIK BALA
May 05, 2009
-   My lens was going in and out as well... same as the rest of you...I smacked it on a mouse pad a few times and now it worsk fine. There was some sand in the lens that was preventin git from opening.
Thanks!!!-   Guest
Apr 28, 2009
-   this is very frustrating. i had no problems up until this point (about 2 years), and now i can't wack it hard enough to make a difference... boo for me! -   Guest
Apr 26, 2009
-   Had the same problem as of yesterday.  Chatted with Sony support online and they could not fix it.  Asked me to send it in for repairs.  The flat rate, assuming it qualifies for it, is $91.  Decided to try banging it.  Took more than three soft bangs.  Actually a few "medium" bangs against the kitchen counter and guess what?    The camera now works fine.-   FixYabelieve
Best Solution
posted on Apr 21, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Just figured I would add my experience as well. No amount of whacking worked for me, so I used pliers and pulled the lens all the way out while it was powering up and that worked for me.
Solution #2
posted on Mar 08, 2008
Very Helpful)
u suck
Rank: Apprentice
Rating: 98%, 4 votes
I would just like to say i tried "tapping" it "hitting" it and all that other magic u all suggested. MINE IS FING BROKEN FOREVER. DON"T TRY THIS PEOPLE!!!! I'll be spending the $200.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 27, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i as well as many others was having the same problem...i can suggest 2 things. First try resetting the camera. Make sure it is off and take out the battery. Then hold down the shutter button for 30 seconds. Put the battery back in and then see if it works. If this doenst work but you are able to get your camera on another way you can set the camera back to its factory settings by going to the menu and under the setup scroll down to initialize. Click right and then click on OK. This sets the camera back to the way it was the day you got it. Internally of course.
Solution #4
posted on Nov 12, 2007
Helpful)
melindabeth
Rank: Apprentice
Rating: 92%, 7 votes
I suggest reporting this problem to Sony whether tapping on the palm of the hand works or not. Go to: http://esupport.sony.com/US/perl/emailform-di.pl?template=EN or calling 800-222-7669. They need to know how prevalent this problem is. It is unacceptable to produce a product that breaks 18 months after normal use. It is surprising to see how many people are completely satisfied with this solution of tapping the camera. I can get my camera to work as well, but I don't like that the camera is unreliable. There is obviously something wrong with the camera that should be addressed by the manufacturer. I am considering converting to Canon. My parents owned a Canon that developed a problem a couple years after initial use. Apparently it was a common problem and Canon was willing to fix it at no cost. Let's let Sony know about this common problem and maybe they will fix it.
Was this helpful?
Yes
No
Solution #5
posted on Oct 27, 2007
Somewhat Helpful)
mbf1326
Rank: Apprentice
Rating: 76%, 2 votes
I was in the most picturesque place in St. Emilion in France when my camera DSC W50, a gift from my hubby last year,suddenly just won't let me take pictures and kept on showing "access" and switch off the camera notice!  Luckily my hubby had brought his other Sony camera which he lent me so i still had pics of the rest of my holidays in Versailles and  Arcachon.
When i got to the UK, i searched for anything that could help me  sort out my camera's problem then i found your site! IT SORTED OUT MY DSC W50! It didn't work at first with a couple of gentle palm taps, then i tried the tap whilst powering up and BLIMEY...... It WORKED!
THANKS SO..........much!!!!!!!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
posted on Sep 06, 2007
Somewhat Helpful)
lainiel
Rank: Apprentice
I was having the exact same issue with my dsc-w55 and I followed the solution of another post from this site which was:
"There is a problem internally with the lens. Likely, the focusing lens is jammed up. The lens will need to be disassembled and fixed, if possible, or replaced.
Occasionally, a good "whack" in your hand can fix it. Just don't hit the lens, or lcd; or you can break them. Then there will be more damage."
I gave it THREE good "whacks" in the palm of my hand, was careful not to hit the lens or LCD and VOILA! I just shot a few pics with my camera and so far so good.
Was this helpful?
Yes
No
Solution #7
posted on May 29, 2008
Very Helpful)
asfafds
Rank: Apprentice
Rating: 100%, 1 votes
ok i think i went a bit far. =(
after missing out on some really great fishing shots because of my camera playing up. it just sat there on my shelf untill i found this website. all the advice led to whacking it. so i tried it.
after whacking it and pulling the lens and pushing the lens.
it still didnt work. then somehow out of frustration. i grabbed the lens and twisted it. it clicked and was stuck there. neither in nor fully out. great! now ive done it. its even worse than before. so i decieded to undo the screws to take the lens out. now im sitting here with the lens in 4 pieces. i dont think its ever gonna work again.
so the moral of the story... just keep whacking it and dont be tempted to open the camera up. haha
luckly i bought a new W150 camera. if that plays up its going straight to sony under its new 1 year warrenty.
good luck guys....remember dont be tempted to open up the camera... keep whacking it till it works.
Was this helpful?
Yes
No
Solution #8
posted on Mar 27, 2008
Somewhat Helpful)
jimhornung
Rank: Guide
Rating: 84%, 8 votes
Knocking the camera sounds like it works but may create another problem. I have had this problem with p-100 , p-200 and now the w50, I have found a small drop, of wd40 placed on both sides ,two opposing sides,of the lens ring where it extends from the body will work also. Don't spray, its a bit too hard to control amount deposited. Use a toothpick or a stick to dip and then drop the oil.
Was this helpful?
Yes
No
Solution #9
posted on Oct 06, 2009
Not Rated)
ritaroy_mass
Rank: Apprentice
Rating: 0%, 0 votes
Just like million others on this site I tried gently tapping the camera and then twisted the lens a bit and it just started to work! Can not thank the site enough! But should definitely report this massive defect in the Sony Cybershot to the company.
Was this helpful?
Yes
No
Solution #10
posted on Jul 31, 2009
Not Rated)
igotbook1112
Rank: Apprentice
Rating: 0%, 0 votes
I have or should i say had the dsc-w50 Its now in a pile of broken pieces in front of me. I took it apart trying to fix the same Problem: I receive "access" error when I turn on my camera. The lens continually tries to open and close. This repeats until I get a message: to power off and restart again. I tried that many times with no success. I change my battery with no success. I changed my memory stick also without any success. I'm not some electronic genius but I've taken apart various electronics including my dsc-T100 Sony camera and fixed it!!! DON'T open this camera for this problem or you won't have a camera. Don't try twisting either of the lenses at all!! If you do you'll just jam it more. (I did this and regret it) You probably don't want to push the lens either because it doesn't just push in and out. It twists in and out so by pushing the lens your pushing against the motion of the twisting. (I realize that now that i have the camera in 25 little pieces in front of me) My suggestion DON'T take it apart no matter how skilled you think you are. I would listen to the voice of the people who got their camera's working by slamming them.
Was this helpful?
Yes
No
Solution #11
posted on Apr 15, 2009
Not Rated)
j_hornok
Rank: Apprentice
Rating: 0%, 0 votes
Hilarious...I thought everyone was crazy because I tried hitting it hard against my hand a few times, and still nothing...then all of a sudden, it's like I could hear the wheels turning in my camera again, and TA-DA!!! It worked again! I'm so happy because I'm going on vacation in a couple days and I can actually take some pictures!!! :) :) :)
Was this helpful?
Yes
No
Solution #12
posted on Aug 17, 2008
Not Rated)
Schmeaserch
Rank: Apprentice
Rating: 0%, 0 votes
I see a lot of replies around the fix of tapping or banging the camera gently, but there's another solution that worked for me. Apparently, sister Cybershots have the same issue. There are a ton of posts on this problem. What worked for me was tugging outward on the lens gently. There are two lens barrels on my W50 - a smaller one protruding from a larger diameter base component. With thumb and forefinger, I just pulled gently outward on the base barrel away from the housing of the camera and felt the smallest nudge, or click. The viewfinder came on instantly. Since then, repeated ons and offs show the camera working fine. Hope this helps others!
Was this helpful?
Yes
No
Solution #13
posted on Mar 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I tried the banging thin...no such luck..it keeps telling me to turn it on and off again. I just e-mailed tech support. hopefully they will help.
Solution #14
posted on Mar 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Are you joking? I am in disbelief like the rest of you. It freakin worked!
Whack the camera against the palm, or on a hard surface, like a wooden floor. incredible!
Solution #15
posted on Feb 25, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
okay well i had this exact same problem i tried everything i read but it still wouldnt work till i decided to push the lense all the way in i turned on my camera they came in and out in and out till it stopped i turned it on and the lense came out and my camera works perfectly noww :) imm soo relievedd!!
Solution #16
posted on Jan 10, 2008
Not Rated)
HannBannDitt
Rank: Apprentice
Rating: 85%, 3 votes
i cannot believe that!!! i felt like a goon smacking it loadsa times. but you can hear soemthing clicking inside when its dieing =] When it stops its fixed. I kinda had to beat it the camera up a bit though. It wudnt work, and i thought ' What the hell. Its broken any way!', it worked!!! . Awesome Stuff. Thanx Guys =]
Was this helpful?
Yes
No
Solution #17
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I cannot believe it! Had the exact same problem with access coming up and whacked it 6 times and then it works! Incredible!
Solution #18
posted on Dec 26, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
WOW I WAS SO MAD BECAUSE I PAID $250 AND THE LENS WOULD GO IN AND OUT ALL OF A SUDDEN I HIT IT A COUPLE OF TIMES AND BOOM IT WORKED!!!! THANKS GUYS
Solution #19
posted on Dec 19, 2007
Not Rated)
chelli
Rank: Apprentice
As with everyone else, I couldn't believe this worked. My daughter has a DSW 50 and the quote to repair it was $250.00. We were just going to buy her a new camera. She whacked it on her palm a couple of times and is now thrilled that the camera is working again.
Thanks to everyone.
Was this helpful?
Yes
No
Solution #20
posted on Dec 04, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i had the same problem with my w90. i took it out of my pocket and it wouldn't work. i held down the power button for 30 seconds and it worked again! hope that helps. the palm slapping did NOT work...it just made it make a funny noise. i thought for sure it was then broken.
Solution #21
posted on Oct 30, 2007
Not Rated)
catdk
Rank: Apprentice
I dropped my DSC-W50 on the floor this morning and got this problem too. After reading this, scepticallly I dabbed the camera in my palm 3- 5 times. It WORKS ! So happy, going to Venice tomorrow! Thanks
Cat, Denmark
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-shot DSC-W50
Questions and Unsolved Problems for Sony Cyber-shot DSC-W50
Do you recommend Sony Cyber-shot DSC-W50 Digital Camera?
Answer
Answer
my psp ms is not working please solve this problem
Answer
how to get warrenty on sony cybershot DSC w150
Answer
My Sony DSC-W90 has a start up problem with the lens tracking in and out and then asking me to turn... (More)
Answer
when i turn my camera on it says access but I cant see anything thru viewer,and an orange light... (More)
Answer
hi when turn on my sony dsc - w120 it says incompatible battery. What do i do
58 Other Users Have The Same Problem - Continued
Comment by email2rajeev, posted on Apr 23, 2009
Hi, i too have the same problem, just happened yesterday....by the way ....is there any solution that works ?
Comment by catsrcool10, posted on Apr 22, 2009
my cameras a DSC-W55; the tapping isn't working for me, nor the lens twisting and I don't want to break it by playing with the lens even further. How many times do you need to tap and how hard? This is a stupid problem!! I love my camera....
Comment by heather1227, posted on Apr 17, 2009
when you turn on it just says access and then ask you to turn power off then on again. nothing happens
Comment by Guest, posted on Apr 11, 2009
thank you sooooooo much, it was so simple to sort out, just a gentle pull on the lense
Comment by Guest, posted on Mar 21, 2009
access, access,access, access, that all the darn thing does...so I'll give it a couple love taps and see.
Comment by dhanya93, posted on Mar 20, 2009
i have the same problem!
Comment by Guest, posted on Mar 15, 2009
Same problem....as the other 47.
Comment by Guest, posted on Mar 12, 2009
it keeps coming up with me too. sometimes if i bash it around and press all the buttons and stuff it will start working but once i turn it off it comes up again the next time i turn it on. i think there may be dust or something inside of it. cant find the reciept but i think its still under warranty. . .
Comment by mrsgourdin, posted on Dec 20, 2008
Same problem as everyone else...banging doesn't work. Any other suggestions?
Comment by Guest, posted on Dec 19, 2008
OH MY GOSH!! I JUST BANGED IT TWICE AND IT WORKED :):):):):):):)
Comment by Guest, posted on Dec 17, 2008
Wow!, it took some pretty hard bangs on my plastic storage container but it now works.
Comment by Guest, posted on Dec 14, 2008
The soltion worked for me.
Comment by Guest, posted on Sep 16, 2008
I had the same problem with my DSC-W50 and smacked it on my desk 3 times and it's fixed!!! I was skeptical reading through this but thought what the heck... try it anyways and it friggen worked!
Comment by Guest, posted on Jul 27, 2008
same problem..whacked it hard a couple of times against padded chair...works fine ever since.
M.
Comment by SPADRU, posted on Jul 23, 2008
Unbelievable!!! Couldn't take any more pics at brother-in-laws wedding 'cause some drunken nutjob knocked the camera off the table. Thought I was in for an expensive bill. Followed the advise of smacking it around a few times, and voila!!! Took a few smacks to the side, top, and bottom to get it working but it seems fine now!!!!
Comment by sweetmelyssa, posted on Jul 22, 2008
WOW! I had the exact same problem as everyone else! There's something going on with the lens as it tries to retract. It makes a different sound than usual. The banging it on my desk thing worked, but the zooming in and out to take pictures is a little slow. I still would like it to work properly and not have to bang on it.
Comment by kschaefer, posted on Jul 17, 2008
I am having the EXACT same problem. I am so frustrated!
Comment by smaters, posted on Jul 14, 2008
I had the exact same problem! I tried a couple of the suggested techniques (i.e/ recharge battery, hold down shutter button....) .. I then tried the good old 'whack' it method- WALA! ll fixed. I am giggling up a storm right now!
Comment by Guest, posted on Jun 26, 2008
Access error on power up, lense cycles when attempt to power off. Followed the 3 bang fixit method I found on this and other sites. Took a couple extra bangs on the countertop, but amazingly the camera woke up. Woking fine now, thanks to whomever discovered this fix.
Comment by mcdonbe, posted on Jun 22, 2008
I have the same problem
Comment by mcdonbe, posted on Jun 15, 2008
I have the same problem: dropped camera, now "access" comes on, then the turn on and off button (lens goes in and out).
Comment by Guest, posted on Jun 08, 2008
"Access" is displayed on the screen and the lens keeps going in and out.
PLEASE help!!!!!
Comment by Manuelvega, posted on Jun 02, 2008
i have the same problem of my lens going in and out and the access message pops up telling me to turn the power off an dthen on again.
Comment by buffygal_87, posted on May 29, 2008
i tried reseting it but it didn't work.....
when i yurn on my camera the access keeps on popping up and the lens constantly goes in and out.....then it comes up for me to power it off....
i tried banging it but that didn't help....
Comment by Guest, posted on May 27, 2008
Thank you!! I came on here to try to get some info to fix my Sony Cybershot DSC W50 with it reading access only.
This happened a while back while still under warranty and waited like 2 weeks to get it back fixed, with no charge.
So now I have the same problem, and tapped it like 3 times like someone suggested and it is now working!! Unbelievable!
Thank you thank you thank you!! lol I am still in shock, but a happy shock!
Comment by otooler, posted on May 13, 2008
i have the same think wrong wit my camera, i have hit it and hit it, new battery new card, everything, nothing wroks, it might just be sony's way of making more money of people, can some please help me, some one that dosen't work for sony, i can't pay any more money on this thing, thanks
Comment by Guest, posted on Mar 21, 2008
I'm only posting this because I was suprised that "three smacks against the palm" actually worked for me. I've had this same problem with the lens and "Access" error a number of times before.
Yes, you can help along the lens by pulling it - but three taps against the palm of your hand (while the camera is on is what worked for me) had it working on its own again! Thanks!
Comment by Guest, posted on Mar 19, 2008
Cybershot DSC W55 "Access Error" on power up - can't do anything ...message to say power off and try again. Numerous power resets do nothing.
Followed advise and tried to "shock" it into action, but still fails.
So very gently pulled lens out a bit further on power up, and Bingo! Now works fine!
Phew! What a relief, I was really worried the camera was screwed, but it looks like a bug in the camera on power up where the lens doesn't go out to it's full extent and fails it's power up tests!
Thanks folks... a real life saver !!
Comment by khearter, posted on Mar 18, 2008
I have the same problem, but it's not because the lenses are jammed, because they tend to go in and out as the message is showing on the screen.
Does anyone know how to fix this?
Comment by PaJamers, posted on Mar 09, 2008
Camera turns on with access across the screen, the lens opens and closes many times, then turn off power and on again, there is also an orange-yellow lite the bottom one flashing possibly a code of some kind that I don't ever remember seeing before.
Comment by Amir Sharif, posted on Mar 06, 2008
Amir Sharif
Please e-mail me.
Comment by Guest, posted on Mar 05, 2008
When itrying to get camera (w35)on an error will cccur i.e turn off power and then on. The lence will not come out, but we can see images which are taken before this problem. Sir please assist me
Comment by peterhopgood, posted on Feb 24, 2008
Had the same problem whilst on a skiing holiday, and I thought it was the cold. Tried warming it up, charging the battery, resetting, shaking it, but to no avail. I couldn't believe your fix, but after reading all 35 of them I tried whacking it on my palm - didn't work; then pulling out the lens - didn't work; them whacked it on my palm whilst powering up, and Bingo! It now works like a dream! It is a great little camera, but I agree with the others, a little used camera which is well looked after should not go wrong just after the guarantee runs out!
Comment by mambriz, posted on Feb 21, 2008
My son had the EXACT same problem that you all are describing. I was just about to spend $111 to have it repaired but I read your solutions and WOW was I excited that slamming it on my palm 4 times did the trick. It works perfectly.
Thank you so much for saving me $111 and months of aggravation!
Comment by LBBJMB, posted on Feb 18, 2008
My camera developed the same problem yesterday. At first I thought it was due to cold operating conditions or the batterfy running out. When bringing the camera indoors and recharging the battery didn't work, I got online and found this website.
The suggestion to pull the lens forward upon powering up didn't work.
Pounding the base of the camera against the palm of my hand worked great. After three slaps, I could access pictures I'd taken, though I still couldn't take photos. After three more slaps, the access error message went away, and the camera works fine again!
Thanks to everyone for posting this layman's solution--sure saves time, money and aggravation!
Comment by Guest, posted on Feb 15, 2008
I did what the other guy did smacked it against my hand 3 times nothing happened, did it again much harder and bingo view finder lit up and it works perfect thanks for the all american fix
Comment by mohdodeh, posted on Jan 13, 2008
it just give me access error
Comment by Tikitiki, posted on Jan 07, 2008
Same same. Power on camera, "Cyber-shot" appears on the screen followed by "Access". While this is happening the bottom orange light is flashing by the manual veiwer, while the lense is going in and out. Next the camera will shut off lens and show on the screen "Turn the power off and on again." I have tried this, even removed the battery, no joy. I can still access menue and any photo in the memory.
Comment by roy2k, posted on Jan 02, 2008
i have the exact same problem and i think sony must know that their product is unreliable. damn them !
Comment by Gypsii, posted on Jan 02, 2008
Can't get access...son dropped camera and now lens goes in and out. Can't afford a dealer fixing...help please !
Comment by Scrimshander, posted on Jan 01, 2008
Had the same access problem and figured the camera was junk. Tried all the usual fixes with no results. Found FixYa and checked out the posts. YA RIGHT!!!! I thought. Nothing to lose so three light taps on the hard part of my palm. 2nd time it started working. Oh well so much for modern technology but I'll keep a hammer around just in case. Thanks everyone for a simple solution.
Comment by aclayton, posted on Jan 01, 2008
My 6 month old daughter was having a "cute moment" on her first Christmas, and the camera broke! The lens kept moving in and out and the screen read "access"- The camera is only about 9 months old and has never been abused.
Comment by Guest, posted on Dec 24, 2007
I turn the camera on and the word Access appears and the lens move in and out some and then iake the turn off the camera and turn it back on. If I do what it ask the cycle starts over if I do nothing the camera turns off.
Comment by Guest, posted on Dec 23, 2007
damn! my camera is n0t w0rking! i have tried d0ing all thee p0ssible things that y0u guys suggested! i tried hitting s0 many times but it still did n0t g0 thr0ugh?? any m0re suggesti0ns? but i d0 have warranty...s0 sh0uld i send it in already? but i als0 need it t0 be fixed by t0night!
Comment by redege, posted on Dec 10, 2007
Same problem, and although the palm was not enough, the benchtop tap did the trick!! Hurray!.Can anyone tell me if this is happening all the time, or at least more than once, and should I progress to a hammer?
Comment by NVKK, posted on Dec 08, 2007
Comment by ek250, posted on Dec 07, 2007
Comment by happyfacell, posted on Dec 07, 2007
Dropped my DSC-W50 and have the same 'access' problem
Comment by peranikan, posted on Dec 04, 2007
Same thing happened to mine about a month after the warrenty expired. We had snow after thanksgiving, and I put it in my pocket to take some pictures of the kids in the snow. It worked fine, but when I brought it inside five minutes later - then lense would start to move when I turned the camera on, and the display said "Access" then "Turn the power off and on again" I turned it on and off a couple dozen times, recharged the battery, with no improvement.
Comment by Guest, posted on Nov 28, 2007
the same with my w-50
Comment by Guest, posted on Nov 22, 2007
When I turn the camera on I get an orange flashing light near the view finder and the lens keeps extending and then retracting. The Instruction then follows "turn the power off and then on again". If I do this nothing changes and we still cant use the camera.
Please help. The camera is a Sony Cyber-shot DSC-W30 6.0mega pixels.
Comment by Raadhy, posted on Nov 13, 2007
Comment by kevbhoy, posted on Nov 05, 2007
have tried your suggestions a number of times but not yet working, any other ideas please
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Cameras Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
