Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
USB Storage Device
I have a USB Storage device which works only on 1 PC and not on another. Pls advise. Thanks
Yep, both comps are equipped with USB 2.0 The prob is : the USB Storage device worked previous to making h'ware repairs ( SMPS ). Small pen drive works on System but 100 GB drive does not. 100 GB has no individual power supply but draws from USB port. Could this be related to BIOS?
Posted on Sep 06, 2007
  • 29 Answers
Do both computers have USB 2?
SOURCE:
Pls i want to store, mass storage controller driver
The PC should install that driver itself automatically when you connect a generic device to it such as a flash drive. If it does not try connecting your device to a different USB port.
If the drivers will not install it may be that you have a faulty mass storage device
Jun 16, 2015 | Sony VAIO VGN-N170G/W 15.4-inch Laptop...
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
I have a thompson ths220 recorder and am unable to record programmes. I go in to epg menu and book a programme but the usb file is not compatible
It is possible that the USB drive is not formatted to the required specification (FAT/FAT32).
Please visit the following link and update to the latest firmware - http://www.thomsonstb.net/en/products/satellite-receivers/ths220
You'll also find a Manual there.
As per the manufacturer -
It is recommended to use USB 2.0 storage devices. If your device is not compatible to USB 2.0 specifications, multimedia functions of the receiver might not work properly.
THOMSON cannot guarantee compatibility with all types of USB storage devices.
It is advised not to store important information on USB storage devices used with the receiver. Always make backups of data on your USB storage device before using it with this receiver. THOMSON will not take responsibility for any loss of information or circumstances caused by loss of information.
Please ensure that either the USB device is already formatted to FAT/FAT32, or format the USB device via your receiver.
May 30, 2014 | Computers & Internet
Hi, im having problem with my windows usb it cannot be detected by my windows xp.. in the device manager the mass storage device is marked (x) on it. what would i do to make this functional on my...
First of all try changing the usb port you are using I am sure that there will be more than one usb ports in your PC. After this try using another similar USB device.
I mean if you are trying to plug in a Flash drive use a different one or If you are trying to connect an external Hard Disk (as it is obvious from the mass storage device marked with an x as you have pointed out). Try using a different External Hard Disk that you may borrow from someone checks will help you locate the problem. The reason why your USB device is not being detected by your PC must be the driver of the USB drive is out dated. Check the version of the USB Is it 2.0? or the driver might have been corrupt.
You can download USB Mass storage driver from the following site. You can search for USB drivers on other sites also.
http://download.cnet.com/windows/usb-drivers/
Best of Luck!
Jul 31, 2010 | Microsoft Windows XP Professional for PC
I have a Maxtor Personal Storage and I am
I found this info on Seagate forum (Seagate owns Maxtor). http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&thread.id=38
The error 10 is an indicator of a drive gone bad. But, there are a few on there that say they were able to get them working again. If you device is under warranty, try working with Seagate support first for a replacement. If you have data on them, you may need a recovery specialist to salvage that data.
Bret
www.1-2-1ComputerServices.com
Oct 06, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Not function download pictures to the PC wit Windows 2000
My best advise for this issue it to purchase a usb card reader and remove the card from camera and use card reader to upload the pictures to your computer.
Apr 16, 2009 | Computers & Internet
Can't see usb mass storage devise in my computer, though inserting it prompt says that device installed and are ready for use
Delete the USB devices in Device Manager and again connect your USB device.Let it rediscover your USB device.
If you dont know how to delete USB device then check following steps.
1) Right Click on 'My Computer' icon on your desktop and select properties.
2) Now select 'Hardware' tab and click on 'Device Manager'
3) You will see the USB device as a mass storage device.Uninstall that device.
Thanks
Feb 27, 2009 | MSI P4MAM2-V Motherboard
About Sigmatel S3
once u have connected USB from mobile to system... u get a message option of mass storage and com port.... better select mass storage for easy process... wen u select mass storage automatically the memory card will be displayed on my computer ( same a pen drive)..... NOTE: this process does not shoe phone memory..... only u can access memory card.... thank you... VINAY
Aug 26, 2008 | Handmark Software MobileLists (950142) for...
Usb divece
run device manager and remove auknown device specially usb storage device and restart your computer... or try other usb port...
Apr 02, 2008 | Computers & Internet
Iomega portable hard drive
Please check in device manager that storage mass device is not showing yellow mark if it is please first remove any storage device showing yellow mark in usb devices in device manager >
You wil find device manager in windows 2000/xp in control panel >administrative tools>computer management ..then click on device manager
Second thing is please remove/uninstall any storage device information from device manager
Restart the pc and then go to device manager and see there should be no entry of storage device in usb root devices .After this fix your usb device and it will work definately
Regards
Balisonu79
Feb 13, 2008 | Iomega Zip 100MB (31714) External ZIP...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
