Question about Mitsubishi VS-50605 50" Rear Projection Television
Picture "jumps" at startup for about 20 minutes until warm.
When I turn my set on, the picture seems to jump up and down erratically. It stops and looks fine after about 20 minutes or when it is warm. What could be the problem?
    Sniper:
  • 140 Answers
You have some leaky filter caps. They are: C2C52 = 10 MFD 50 VOLT (off the base of Q2C51 on the signal board)Also check C2P05 = 100 MFD 16 VOLT (off pin #3 of IC2P01 on the signal board) and C2P03,C2P08 = 100 MFD 16 VOLT both on the signal board.
Posted on Sep 07, 2007
SOURCE:
Picture is jumping lg55lb7500
10 Ways To Fix A TV Picture That Jumps Jerks or Skips ...
https://removeandreplace.com/.../10-ways-to-fix-a-tv-picture-that-jumps-jerks-or-skip...
Aug 5, 2016 - QUESTION: When I watch my TV, the picture sometimes jumps. How do I test it to see if it's the TV or another issue? If your TV picture is jumping while watching cable, satellite, or streaming, there are a few things you can check. See below for the best solutions to fix a TV where the picture seems to "jump" or ... Missing: lg55lb7500
Picture jumps every few seconds. - Forums - CNET
https://www.cnet.com/forums/discussions/picture-jumps-every-few-seconds-375282/ Dec 26, 2009 - 5 posts - ‎2 authors
I have a Samsung LN -T4061F model I bought two years ago. Over the past two days I have noticed that the TV picture jumps every few seconds. In the trouble sho... Picture Issue on my Samsung Television/Blu-Ray
23 Aug 2010
Samsung UN55C8000 Jumping images
7 Apr 2010
More results from www.cnet.com
Missing: lg55lb7500
How to Stop Jitter on a LCD TV ' Techwalla.com
https://www.techwalla.com/articles/how-to-stop-jitter-on-a-lcd-tv Mar 31, 2015 - When using an LCD television you may notice occasionally that the picture jitters, or jumps down the screen. This makes watching the set rather disorienting and may even cause headaches. Fortunately, there are a few troubleshooting steps you can take to correct the jittery picture issue before calling on a ... Missing: lg55lb7500
Picture jumping - The eBay Community
https://community.ebay.com/t5/Technical-Issues/Picture-jumping/td-p/26963824 In the last few days, when I have been viewing photos/pictures in a seller's listing, they have been flickering and jumping until I viewed the.Missing: lg55lb7500
Feb 21, 2018 | Televison & Video
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
http://www.back2lifeelectronics.com/Guestbook.php
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
When you turn the tv on it goes to the settings screen and you can't get a picture for about 20 minutes until it warms up
Fist is contact Philips to see if this (with the model number) is a known issue or if there is a software upgrade available for this set.
Apr 08, 2012 | Televison & Video
When first turn on, picture jumps up and down for a minute or so then stops when set warms up
There is very little that can be done for this. It is a problem that occurs to all rear projection televisions sooner or later.
Mar 02, 2011 | Mitsubishi VS-60707 60" Rear Projection...
My Samsung 23 inch LCD tv works fine for 25 minutes then the screem starts jumping..
There is a Anynet Setting under the input tab. It has to be on the right setting or the picture Jumps after 20-25 minute. Once I adjusted it to the right setting it stopped jumping and it now works Perfect. Would nt have figured it out if I wouldnt have been messing around with it as a last chance deal.
Dec 27, 2009 | Samsung LN-R237W 23 in. LCD Television
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Jul 02, 2007 | Toshiba 36HF72 36" TV
Wavy Screen on Startup
I gather from your post that wavy can mean two possible things as the TV comes on, you see the picture flow like ocean waves? In this case you may have 60Hz hum modulating with the picture, this is actually unlikely these days, but I have heard it happens sometimes. The other thing it could be is light horizontal tearing. This happens when the horizontal frequency is too high or too low. You are not going to like my solution because I feel that for problems like this the set must be analyzed not just subjected to "shotgun troubleshooting", so here I go, Take the TV to a repair shop.
Feb 28, 2007 | Toshiba 50H72 50" Rear Projection...
4 yr old Toshiba jumps when turned on
take it to a tech if you have not done so. your problem is lose solder.your board needs to be rsoldered over to connect your component properly over the years heat from the operation of the tv cause the soldr to lose grip on the board.good luck
Jan 07, 2007 | Toshiba 36HF72 36" TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
102 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
