Question about Sony Cyber-shot DSC-W100 Digital Camera
Sony cybershot dsc w100
After i had loaded pictures from my camera onto my laptop and removed the camera, i turned it on and it opened with an "internal memory error" message on it. the manual said to turn it off and on again, and i have, with differing time lengths but nothing has helped. what do i do?
  • evell Sep 23, 2007
    i tried, but it doesn't let me.
    oh no....
  • evell Sep 25, 2007
    how does that work?
  • 69 Answers
Format the internal memory, you may have accidently written somthing incompatible to the memory from the lapt top (virus ??)
Posted on Sep 21, 2007
  • James sMITH Sep 24, 2007
    Can you acces the cam from your laptop,
    if can access the meem via your laptop, perhaps you can format using the computer format command ?
I took 10 pictures without the memory card so the pictures are on the cameras memory i suppose. I'm now wanting to load them onto my computer but my picture program as well as computer can't see the...
Took a bit to find this this bad news in the manual but what happens now is to get the pictures from the internal memory to the computer as a down load you need to first insert a memory card format the memory card and load each picture from the internal memory onto the memory card one at a time once that is down then you can download the memory card to the computer then you will need to reformat the memory card and then go back into the internal memory erase each one of those images and format the internal memory. Now the GOOD news, you only have 10 pictures. Don't forget to do the formatting.
Jan 04, 2011 | Olympus Stylus 790SW Digital Camera
I have a Fuji FinePix F480 which is brilliant but it isn't downloading all my shots onto my computer. It is showing a message that I have internal pictures. My question is how do I get these pictures to...
I've attempted in the past to download from the internal memory to the computer before with no success. What you can do is put the memory card back into the camera and transfer the internal pictures to your memory card (your camera refers to these as "frames"). I'm not sure if you have a manual or not but what needs to be done is selecting copy using the multi-control button on the back of the camera select "IN" for internal and arrow from internal to card. the only sticky thing about this is you need to do one "frame" at a time. Make sure you have the room on your memory card before doing this. You might want to format the memory card first before you do the transfer from internal memory to your memory card. Then once the Internal "frames" are all on the memory card you can down load them to the computer as "normal"
Dec 18, 2010 | Fuji FinePix F480 Digital Camera
When I try to take a picture i get a message on the screen that says "Internal Memory is full". I put all the pics that were on the card onto my computer but i"m still getting the same...
The internal memory and the memory card are two different things. To erase the internal memory, remove your memory card, go into the menu and find "format" and follow the on-screen instructions.
Oct 29, 2010 | Kodak Easyshare C182 12MP Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
Camera or memory card "CARD FULL" error
Check to see if in your settings you are putting the pictures onto the memory card or the cameras internal memory. If there is no internal memory, then I guess that's no help. Also check to see if the card is write protected (a little switch on the side of it).
Apr 13, 2009 | Fuji FinePix Z2 Digital Camera
"Internal memory requires formatting."
This error message indicates that the internal memory in the camera requires formatting or is corrupt. You must format the internal memory. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a memory card during formatting may damage the card. (Formatting internal memory also erases email addresses and album names. To restore addresses and albums, see Kodak EasyShare software Help.)
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
"Internal memory is full"
This error message means that there is no space remaining in the internal memory. Turn off the camera and insert a memory card, or transfer or delete pictures
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
The camera screen displays an "Internal memory is full" error message. What should I do?
This error message indicates that there is no more space in the internal memory of the camera. Delete pictures from the internal memory or change the storage location to Auto. Then turn off the camera and insert a memory card.
Sony Cyber-shot DSC-W100 Digital Camera Logo
78 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
