Question about Samsung LTN1565 15 in. HD-Ready LCD Television
Power light blinks
Power light continually blinks. no picture or sound. Is it worth trying to repair or throw it in the trash.
  • 1 more comment
  • Anonymous Dec 05, 2007
    POWER LIGHT BLINKS TV WILL NOT TURN ON UNTIL LIGHT STOPS BLINKING
  • Anonymous Jul 02, 2008
    I had no problems with this tv set at all, but had a few months of not using it and one day pluged it in to use as a pc screen and the blinking green light, but one day someone noticed it not blinking and it turned on, we left it on for 5 days straight, but once turned off it started again. months later after loking inside at c21 nothing looks damaged, and pluged it in and a few hours later the light stopped blinking and I refuse to turn it off yet. any other type of solution to fix this as you can plainly see the TV is 100% fine once turned on.
  • ced4dad Jan 03, 2009
    Power LED at the bottom of the unit flashes off and on. Power supply seems to be the proper voltage. No life in any mode.
  • 3 Answers
I found a solution, Heat. When the set is on and heats up it stays on, but once off for the night it gets cold and can't start, try using a hair dryer on full blast and put the heat around the back top vent like structure and wait for the light to stop blinking, this only takes about 2 min or so
Posted on Jul 30, 2008
Yea my tv wont turn on for nothing and 3 days ago i tried to turn it on and the green power light keeps flashing and it wont turn on. What should i do???
Posted on Jul 29, 2008
  • Anonymous Jul 29, 2008
    GREEN LIGHTS KEEPS FLASHING AND WILL NOT TURN ON IVE TRIED EVERYTHING!!!!
  • Anonymous Aug 01, 2008
    thank you! the hairdryer actually got it to work again!
I am having the same problem and I noticed that the on/off button seems to stick
I get it on and it is fine but next day I have trouble with it again until I get it on again and it plays for hours
Posted on Feb 23, 2008
    New Friend:
OMG - I was so skeptical about the hairdryer thing, but it worked! It stopped blinking, the light steadied and I pressed the on/off switch and the tv work. What the heck...thank you so much....
Posted on Jan 13, 2010
  • mendye Mar 31, 2011
    Great idea...the hair dryer worked, but what's the long term solution? Do I have to use a hair dryer every time I want to turn the TV on?
2 Suggested Answers
SOURCE:
  • 298 Answers
SOURCE: Power light blinks
Circuit board problem pawer supply
and or horilz deflection HV
Requires proffessional Service
May be worth repair. you could
get an estimate, and then decide
whether to throw it away or not
Posted on Nov 24, 2007
Power light blinks
Nov 24, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
We have an 11 yer old sony wega KV-32FV15 We lost picture and sound. Power on swirtch activates the standby red light which just continues to blink (no Sound no Picture0 We know we have the power plug...
the tv is defected needs to be repaired..have a tech repair your tv.the problem is in the power supply or horizontal circuit.could be any thing in one on those circuit.good luck.
Aug 28, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Power light blinking 10x sequentially on a 4y.o.
If you apply the 50% repair/replace rule, it's time to replace rather than repair.
Sep 21, 2017 | Panasonic (TH-50PZ700U) Television
Sony a-1302-180-a
the repair guy is trying to save you some grief, when iv'e seen this in the past they are usually not worth trying to fix as that coolant is rather hard to clean out- nearly impossible to get all of it.
Oct 06, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Blinking power light
I got the same problem too.
Jul 11, 2008 | Jwin JD-VD140 DVD Player
Power led light
Sounds like a power supply issue. If the unit had a good picture, it's worth having it looked at. Call someone that offers an estimate service.
Geno
Jan 24, 2008 | RCA D52W19 52" Rear Projection Television
Projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
Jan 21, 2008 | Televison & Video
Sanyo DS20930 TV Has a Short
It sounds like a relay switch has gone on it. Have you got a friend who could help you in this field. The repair man may charge you more than its worth. I sympathize with you it would be a shame to throw it away but hundreds are doing just that every day ... they are the rich ones!
Nov 20, 2006 | Sanyo DS20930 20" TV
Samsung LTN1565 15 in. HD-Ready LCD Television Logo
689 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
