Question about Nikon Coolpix 2100 Digital Camera
Battery door broken
Is there anyway to fix the door to the battery compartment of a camera. It seems a small plastic piece broke off. I have to take it shut to get it to work.
Yes i have fixed it. Sorry for my spell, but i try. First i kutt off the little broken plastic-bits with a knife. Demontage the four skrews in the battery flip. I take a little bit stainless string ca 0,5 mm dia and ca 20mm long. I hold this string with a handtool (tong)and put a soldering-heater on the end off the string and pusch the string troth down two times and get two holes there the two tabs have been.And after that a bend with a tong the string like an U (2x90 degrees) exaktly after the hole-with. And after that a pusch down the string in the two holes exaktly so high so the little finger on the battery-door go in. Test and try with the battery-door. And take a thinn tong and bend out the string to the left and to the right inside the kamera. Thats it. Work with care and slow and exaktly with mm-tholeranse. Good luck !!
Posted on Sep 21, 2007
SOURCE:
Can I replace the latch or change the full internal chamber?
sir,
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
Jan 09, 2016 | Nikon 1 J1 Digital Camera
I can't keep the battery door cover closed on my Nikon coolpix digital camera L.22
I see this message at least 3 times, so it must be important.
Looks like a mechanical problem. But not having the camera in my own hands I have to do some educated guesses.
Could be something broke off. Could be a small chip of plastic or a very small piece of metal. Difficult to repair it yourself. But you also could look if there is something in the battery compartment that should not be there. Could be just a little bit of debris, that is lifting the battery, (not if the battery is behind the lock) or debris in the door, so you can't close the battery compartment complete, and it can't be locked.
If you can't find anything and it looks as if the battery compartment closes correct, and still you only can't lock the door, please visit your dealer or the Nikon service centre closest to you.
Nov 19, 2013 | Nikon COOLPIX Cameras
I have a canon a 560 displaying low battery even thought i checked and confirmed that the batteries were in good condition.
Here is the suggestion:
The battery compartment cover and the design of the metal electrical contacts is flawed. These acontacts re made of springy metal, but there isn't enough force to press the metal securely against the battery. The end of each contact has a metal tab that prevents it from being bent further out to increase the tension. These contacts are the cause of the low-battery warning.
Some fixed the camera by inserting tiny pieces of plastic foam (i.e., spongy, like from "foam rubber" pillows) under the metal contacts. Used a small screwdriver to gently bend up each metal strip, and stuffed a small piece of foam under it. This provides enough force to keep the contact securely touching the battery.
or You can also try the "toothpick trick" as described in various forums, and it seems to be working. There is a belief that there is a design flaw with the battery compartment door, or the springs that press against the battery. By wedging a toothpick under the battery contacts, it seems to force the contacts into the battery, seemingly helping with the problem that many are facing in this and other forums.
Mar 09, 2011 | Canon PowerShot A560 Digital Camera
Nikon D200 battery door - is it broken?
The battery door is meant to come off so the MB-D200 battery pack can be inserted, but it sounds as if yours has broken. There should be equally-sized rods that form the pivoting hinge, on on top and one on the bottom. Yes, you can buy a replacement part, probably through a local dealer or online. I believe online they cost around $20-$25. To remove the door, you are supposed to open the door to a 60-degree angle to the camera body and gently pull the door off. To replace the door, again, hold the door at a 60-degree angle to the body and gently press it into place. Or you could pay a repair shop an arm and leg to do this for you ($50 or more + shipping if you use a mail order repair shop).
I remember the 'good old days' when film SLR's were made to take a beating. Sadlly, we're in the era of plastic and I always have to remember to treat every piece of equipment as if it were made of glass!
Hope this helps?
Dec 13, 2008 | Nikon D200 Body Only Digital Camera
Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Mar 28, 2008 | Fuji FinePix F40fd Digital Camera
HP Photosmart R927 Battery Compartment door latch
Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Card-cover open
Look for the switch on the memory card door of your camera. Usually a small piece of plastic on the door closes the switch when the door is closed. Check to make sure that the plastic piece is not worn down and is making contact with the switch. You can confirm that this is the problem by powering on the camera while closing the switch manually with a toothpick. Make sure you keep your fingers clear of the extending lens while doing this. If the plastic is worn down or broken off, try attaching a small piece of scrap plastic with super glue.
Dec 16, 2007 | Olympus C-7000 Zoom Digital Camera
Nikon Coolpix 2100 Digital Camera Logo
317 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
