HI,
Its probably because of the enter switch is not activating. Its contacts gone bad. There will be push switch behind the enter pad that you see from the top. you have to replace this by opening the Console, Display. if you are able to do the same please let me know .
Or just remove the Console, Display and take it to the nearest electronic rearing shop. They can do it very easily. and it will not cost a lot too.
Ajin
SOURCE: NOISEY SCHWINN 430 ELLIPTICAL
Hi I'm Ryan, do you know where it is squeeking from? if you can find the squeek try 3 in 1 oil that should stop it.
SOURCE: The console does not work. E-2 shows up on the console.
We had this problem after assembly as well, it turned out to be a bent pin inside the connector to the flywheel housing (where the wires connect inside the lower part of the main mast). It was so bent that it never actually made contact with the connector.
We straightened the pin, carefully reconnected the wires, and everything worked just fine.
This says to us that the "E-2" error message means the console is missing at least one connection from the system. This could be caused by a bent pin, a torn/cut/frayed wire, etc -- anything that might make it lose signal.
So check the lower connection for bent pins, check the upper connection for bent pins, and check all along the wires for any kind of damage.
Hope this helps!
SOURCE: I am trying to remove the covers on my Schwinn 418
Hello there. Unfortunatley there is no way other than removing the crank arms. You do need to remove the nut on the axle and you will need a crank puller. The puller is available at any local bicycle shop for around 10-15 dollars.
Good Luck Tim
SOURCE: My Schwinn 430 Elliptical is not changing
I think I am experiencing the same problem and have removed the shrouds. Are you experiencing a clicking sound while the unit is plugged in? All of this seems to deal with the servo motor. Don't be fooled by suggestions to replace the rpm sensor...this is NOT the problem. I am trying to find out what the initial setting for the servo motor and the tension cable should be. I found a site where you can order the servo motor, but it tells me that it could be months to receive this part. Sigh...
SOURCE: what is the output of the ac adapter for the
It should be at the bottom of the machine in the front facing away from you if you are on it.
