Question about Honeywell HT-800 Table Fan
Cleaning how do you reccomend cleaning the blades on this fan?
  • 625 Answers
Turn the fan over. on the back you'll see ten holes around the circumference of the cage. use a torx screwdriver of the proper size and remove them. the front part of the cage will come off. the blades are a press fit over the shaft and locating pin. have someone hold the body and pull off the blade.
Posted on Sep 07, 2007
SOURCE:
Blades moving but cant feel no air
if it is a newly installed overhead fan check the fan direction switch just above the motor
Jun 30, 2016 | Dryers
Tv repair
I would reccomend replacing the fan or cleaning+lubricating it. You can find a "precision oiler" at a local hardware store. Its like a small plastic tubs with a skinny needle at the end. Its very handy in cases like this. Use that oiler to squirt a little bit of oil into the shaft that turns the fan at the moto ritself. You may have to take the tv apart depending on what model it is. If lubing it and cleaning off all the dust doesen't help you will need to replace the fan.
Dec 09, 2007 | Televison & Video
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
How do I fix my fan from shaking so badly?
Did you just clean the fan? If while cleaning, you bent a fan blade, even a hair it will shake. Blades are perfectly balanced. Moving one just a hair, will cause the fan to shake. Trying to re=balance the blade(s) is futile, you can get it close, but it will take somr patience. If the fan has built up dust on the blade(s) will begin to shake if some blew off unevenly
Oct 07, 2010 | Lasko High Velocity Space-Saving Blower...
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Cleaning black wood fan blades for casablanca fan
I have had good results using a product called Scott's
Liquid Gold. It's available in many stores including grocery stores. I started using it to clean up console televisions after repairing them. Make sure you wipe it clean after using it. The residue will attract dust if you don't. It's sort of a "super Pledge"
Regards.
Zashiban
Jun 25, 2010 | Casablanca Fan 6632T Panama® II Weathered...
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
FAN MODEL# 1010 MP
Hello
This would seem to be the motor heating up and cutting out on a thermal overload. Check to see if the motor area is clean and that the fan blades are clean. To clean the motor you can blow compressed air through it. To clean the blades disassemble the cover remove the blade and clean with a mild soapy solution.
May 28, 2008 | Patton Electric Dryers
Honeywell HT-800 Table Fan Logo
736 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
chargerhp
chargerhp
JonSnell Electronic
JonSnell Electronic
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
