Question about Toshiba 52HMX94 52" Rear Projection HDTV
There is currently a bug with HDMI when you try to run it from comcast box to a tv or through something to a tv. its thinking that you're trying to copy something...but in actuallity you're not. comcast knows of this problem and they are trying to make new boxes to fix it.
y,pb,pr are component cables. the red/blue/green cables that are digital to analog to digital, but will still give you a great picture.
if your using a HDMI cable and have comcast service call comcast and have them bring you a new red/blue/green cable. They may play stupid but don't let them leave without changing cables.
Posted on Mar 17, 2010
0 characters
3 Points
My kf60we610 tv will not turn on. when i press power on the remote, the green standby light flashes a number of times, then it turns red and flashes in intervals of 5 times, then finally just solid...
Thats the error code for the lamp ballast board having an issue. You can get the ballast at under the Sony DLP Circuit board category. They also offer free installation information.
Sep 01, 2011 | Projection Televisions
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Kdf42-we655 works for awhile then no sound or picture - standby light flashes for awhile then turns to red and flashes in sequences of 5 - then after a short bit tv comes up and works for awhile again. tv...
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-55WF655 picture and sound are going on and off. The green light flashes when they are off and when they come back on the picture comes on first then the sound.
These are symptoms of weak lamp as lamp in tv is reaching to end of its working life and will be replaced to fix this issue.
Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Apr 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Projection Televisions
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Toshiba 52HMX94 52" Rear Projection HDTV Logo
102 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
