Question about Video Cameras
Panasonic camcorder We had a flash flood. Since there was water all around and the panasonic camcorder got wet, it stopped working. What do I do?
  • lilydew1 Sep 05, 2007
    What can I do to make the handycam work? It stopped working after it was in a flash flood
    Problem Solver:
  • 15 Answers
Unless you want it repaired professionally, all I can suggest is leaving it for a good few days - weeks even - on a sunny window ledge or airing cupboard. If you're lucky, the water will just be temporarily affecting the electronics, and it might sort itself out when completely dry. If you are unlucky, there may be some corrosion which will remain even after it's dried out. If it looks like coming back to life, remove the tape as soon as you can, run a tape cleaner through it, and use a new tape.
Posted on Sep 06, 2007
My washer dryer stops in mid washing cycle and pause button flashes. Will not move on until I reset it
you could call a repairman of course . noone can assist you with no make/model listed .
Oct 16, 2015 | Washing Machines
She68t52uc flashing light which says E:15 and watertap
Not sure if this will definitely work, but i do believe this is a flood safety device. Try removing the drain pipe from the waste pipe, into a bucket or bowl, and empty as much water out as you can, then, with the pipe on the floor (will get wet), tip the top of the dishwasher backwards about 45 degrees, and hold for a few seconds. It may be that water/suds are still in the bottom of the machine, or the dishwasher detected this.
Dec 26, 2013 | Bosch Dishwashers
HDR-XR160E is wet. How to retrieve my video?
Stop turning it on for starters and get to a specilaist as the cam may have water in it and the parts are already swimming in it. Usually when something is socked we dissemble it and then leave it to dry or blow dry it with a hair drier but, best get to a specialist, ok.
Nov 28, 2013 | Sony HDR-XR160E Full HD PAL Camcorder
Hi. My Panasonic SDR-H60 HDD Camcorder camcorder got wet while at Disney at first it worked when I turned it on but then stopped. Its its a 30 Gb I think? anyway I lost all my memories 3 years worth :(...
If it has a memory card, usually SD or SHD mini-card, buy, beg or borrow a card-reader which plugs into your computer USB port, try copy / recover files from card to PC.
If you can't see the files then maybe try free download Express Recovery.
Feb 01, 2018 | Panasonic SDR-H60 HDD Camcorder
High water in basement, the push button temp indicator reads both leds lite on both ends. i dont know who to reset
1) Call service technician.
2) If water heater flooded, contact insurance company for possible replacement coverage.
3) Manufacturer's suggest replacement of any flooded water heater.
4) Be very careful around wet or previously wet water heater.
Insulation inside tank will stay wet. Household electricity is grounded to water pipes that are connected to gas or electric water heater. Touching wet water heater can be fatal.
5) Read label on side of tank for product identification.
Read manual for possible part replacement.
Apr 20, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a 92 audi 100 that floods with water when it rains but we have not been able to figure out where the water is coming in from because nothing but the carpet itself gets wet..2 inches wet.. any ideas...
Check if the bottom of the door panels are wet. There is a plastic sheet under the door panel to keep water out. If its ripped or become unglued around the bottom it can cause water to come in. They need to be sealed perfectly to work.
Jan 03, 2011 | 1992 Audi 100
Aeg favorit 64070vi, i 30 fault, think that the anti flood switch is triggered
Thanks to all.
What we couldn't work out is what is actual mechanism of anti-flood triggering, and how therefore to reset it - and why all these other fixes work - but then it occurred to us, that problem is when water gets into the base and can't get out.
Our problem was that water inlet at top of washer came loose so water ran down outside the drum but inside the dishwasher, into the base. We tried the tipping method but this just moved water around and I think there must be sensor there which, if it stays wet, leaves anti-flood triggered.
This makes sense because other high level overflows from drum discharge into base - so if it was to overflow, it goes into sealed base only, wets the sensor and triggers anti-flood.
Our solution was patience - tipped it fully on its side, pointed a hot air blower into it for hour or so, then left it overnight. Tipped it back next morning, water which had run into side panel ran out, so it was upright with its base dry - and (touch wood) it worked like a charm.
Feb 09, 2010 | AEG 23 in. Favorit 88070IM Built-in...
Panasonic sdr-s7 camcorder broken lcd panel
how can i help you?better ask the nearest panasonic service
Oct 11, 2009 | Panasonic SDR-S7K Flash Media Camcorder
Video Cameras Logo
266 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
