SOURCE: guardian primepact 50g rv gen starts for 2 sec then shuts down
This story ends with bad gas and silicone in the gen tank
SOURCE: I have a 7500 watt guardian rv generator and it is
Before starting the genset remove the air filter and check the throttle plate on the carberator, it should be closed. If it is opened, then you choke coil is worn out and needs to be replaced.
SOURCE: guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
