Britax Marathon Logo
Anonymous Posted on Aug 16, 2013
Bottom child restraint buckle
One side of the lower child restraint seat buckle will not release. What can I do?
Dorel UK
Level 3:
  • Britax Master 1,637 Answers
  • Posted on Oct 27, 2013
Dorel UK
Britax Master
Level 3:
Answers
1637
Questions
0
Helped
454088
Points
2410
Hi Robert
We would advise you to contact Britax for assistance.
http://www.britax.co.uk/customer-service/customer-service-contact
2006 lincoln town car air bag light is on 5 beeps 5 times
The five beeps - five times would indicate a code 55 , but factory service info only goes to code 53 .
  • Audible tone - DTCs retrieved
  • Air bag SRS system fault
  • REFER to DTC Priority Table.
Did your air bag light flash at all ? Apparently this will do flash the air bag light codes as well .
Symptom Chart Condition Possible Sources Action
  • Air bag warning indicator is illuminated continuously
  • Fuse
  • Damaged wiring, terminals or connectors
  • A faulty diagnostic connector
  • A faulted RCM
  • A faulty instrument cluster
  • Go To Pinpoint Test A .
  • Air bag indicator flashing
  • Air bag/pretensioner supplemental restraint system (SRS) fault
  • No communication with the restraints control module (RCM)
  • Fuse
  • Diagnostic tool
  • Data link connector (DLC)
  • A faulted RCM
  • Circuitry
  • Go To Pinpoint Test V .
LFC - light flash codes .
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Table
DTC a LFC b Description Action To Take - Continuous The Air Bag Indicator is Illuminated Continuously, RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of Signal Ground Go To Pinpoint Test A . B1231 13 Crash Data Memory Full Install a new RCM and impact sensors. REFER to Inspection and Repair After a Supplemental Restraint System (SRS) Deployment . B1317 Continuous Battery Voltage High CHECK battery voltage; to be below 16 volts. REFER to Section 414-01 . B1318 Continuous Battery Voltage Low CHECK battery voltage; to be above 9.0 volts. REFER to Section 414-01 . B1342 12 RCM Is Faulted Install a new RCM. B1869 NONE
Continuous lamp
Secondary air bag warning sounds if another fault is present Lamp Air Bag Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test B . B1870 NONE
Secondary air bag warning sounds if another fault is present Air Bag Warning Indicator Circuit Short to Battery Go To Pinpoint Test C . B1891 53 Air Bag Tone Warning Indicator Circuit Short to Battery Go To Pinpoint Test D . B1892 53 Air Bag Tone Warning Indicator Circuit Open or Short to Ground Go To Pinpoint Test E . B1921 14 Air Bag Diagnostic Monitor Ground Circuit Open Go To Pinpoint Test F . B2292 33 Restraint System - Safety Belt Pretensioner Fault (Driver Pretensioner Circuit Fault) Go To Pinpoint Test G . B2292 34 Restraint System - Safety Belt Pretensioner Fault (Passenger Pretensioner Circuit Fault) Go To Pinpoint Test G . B2293 19 Restraint System - Air Bag Fault (Driver Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2293 21 Restraint System - Air Bag Fault (Passenger Front Air Bag Circuit Fault) Go To Pinpoint Test H . B2294 24 Restraint System - Curtain Fault (Driver Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2294 25 Restraint System - Curtain Fault (Passenger Side Air Curtain Circuit Fault) Go To Pinpoint Test I . B2295 22 Restraint System - Side Air Bag Fault (Driver Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2295 23 Restraint System - Side Air Bag Fault (Passenger Seat Side Air Bag Circuit Fault) Go To Pinpoint Test J . B2296 42 Restraint System - Impact Sensor Fault (Front Impact Severity Sensor Circuit Fault) Go To Pinpoint Test K . B2296 43 Restraint System - Impact Sensor Fault (Driver Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 45 Restraint System - Impact Sensor Fault (Driver Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 44 Restraint System - Impact Sensor Fault (Passenger Side Front Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2296 46 Restraint System - Impact Sensor Fault (Passenger Side Second Row Impact Sensor Circuit Fault) Go To Pinpoint Test K . B2434 51 Driver Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test L . B2435 51 Driver Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test M . B2438 52 Passenger Safety Belt Buckle Switch Circuit Short To Ground Go To Pinpoint Test N . B2439 52 Passenger Safety Belt Buckle Switch Circuit Resistance Out Of Range Go To Pinpoint Test O . B2477 Continuous Module Configuration Error INSTALL a new RCM. B2691 51 Driver Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test P . B2692 52 Passenger Safety Belt Buckle Switch Circuit Fault Go To Pinpoint Test Q . C1414 15 Incorrect Module Design Level Go To Pinpoint Test R . C1947 49 Driver Seat Track Position Sensor Circuit Short to Ground Go To Pinpoint Test S . C1948 49 Driver Seat Track Position Sensor Circuit Resistance Out Of Range Go To Pinpoint Test T . C1981 49 Driver Seat Track Position Sensor Circuit Fault Go To Pinpoint Test U . - - No Communication with the Restraints Control Module Go To Pinpoint Test V . Your best bet have codes checked with a scan tool .
Heated and cooled seat on 2004 expedition stopped working how to reset them
Heating and the cooling both don't work ? Just one seat or all seats ?
Your best bet have it checked for DTC'S - diagnostic trouble codes to start .
Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Faulted CCSM INSTALL a new CCSM and CARRY OUT programmable module installation (PMI). REFER to Climate Controlled Seat Module . B1358 Ignition Switch or Blower Electronics Circuit Short to Ground CCSM Go To Pinpoint Test Q . B2477 Module Configuration Error CCSM This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2486 Climate Controlled Seat Module Voltage Out of Range CCSM DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 294 (WH/LB) for a fault. REPAIR as needed. If okay, REFER to Section 414-01 . Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2488 Thumbwheel Switch Voltage Out of Range High CCSM Go To Pinpoint Test R . B2521 Tach Circuit Failure CCSM Go To Pinpoint Test Q . B2729 Cushion Over-Temp Detected CCSM Go To Pinpoint Test S . B2730 Back Over-Temp Detected CCSM Go To Pinpoint Test S . B2731 Differential Temperature Fault CCSM Go To Pinpoint Test S . B2792 Heat Switch Short to Ground CCSM NOTE: If HEAT is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2792 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1551 (VT/WH) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2793 Cool Switch Short to Ground CCSM NOTE: If COOL is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2793 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1550 (WH/OG) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . U2362 UBP Invalid Data Node ID CCSM NOTE: DTC U2362 indicates a network concern, the CCSM is not the source of the fault.
CLEAR the DTC. If the DTC does not clear, REFER Section 418-01 .
Cannot fold down my rear seat to access the child seat anchors. is there any way to release the rear seat from the boot?
Child Seat Restraints - FSB Forums - FullSizeBronco.com
www.fullsizebronco.com/forum/23.../182333-child-seat-restraints.html
Sep 22, 2010 - My rear seat hasnt been mounted in 6 years and my son Wyatt has ....Join Date: Oct 2006 .... Tether Strap Anchor Attachment for the Second Row Center Seating ... With the rear seat folded forward, remove the bolt retaining the rear ..... If you can't track down the part, send me a PM and I will get my Ford ...
Solution for car seat anchor tether - Tundra Solutions
www.tundrasolutions.com/.../119126-solution-for-car-seat-anchor-tether/
Dec 11, 2007 - I have a 2004 Tundra and I just installed a forward facing convertible carseat. It's almost impossible to get the tether strap attached to the ...
Child Car Seat Fitment in Trucks ' IH8MUD Forum
I washed my daughters graco car seat and now i havent a clue of how to put it back together and i need re assemble it fast please help
Proper installation of a car seat is imperative to protectan infant. Accidents do happen and assuring that the instructions forinstallation of the Graco Infant Restraint/Carrier are followed will increasethe chances of preventing injury or death as a result of an accident. Graco carseats are a popular choice among parents due the availability of products atcommon retail stores, affordability and user-friendly baby gear.Graco Car SeatInstallation
Step 1
Plan to secure the infant seat facing the rear inthe middle of the back seat. If a center position is not available, positionthe seat directly behind the driver's side seat. For safety reasons, therestraint should not be placed in a position where there is an air bag. Ensurethat the proper vehicle lap belt system is in place; manually adjusted lapbelts, automatic locking retractor lap belts and lap/shoulder belts withlocking latch plates are all considered safe for use with the Graco InfantCarrier/Restraint.Step 2
Remove the carrier from the Graco car seat baseby squeezing the lever at the rear of the restraint and lifting the seat up.Place the base in the vehicle facing the rear. Thread the vehicle shoulder andlap belts through openings at the end of the base without twisting the belts.Secure the belts by placing plastic tongue over the belts. Tighten the vehiclebelts by pushing down on the base and pulling out any slack.Step 3Install locking clip to secure shoulder and lapbelt together just above the seat belt buckle. Connect the two belts with thelocking clip. Buckle the lap belt system and tighten by pulling out any slack.Ensure that car seat base is secure by pulling and pushing on it; the baseshould not move sideways, forward or backward.Step 4
Place the Graco carrier in the base. Push down onthe restraint until it clicks and locks into the base. Set the infant in therestraint for travel and place harness straps over the baby's shoulders. Clickthe chest place together over the sternum and lock the buckles into placebetween the legs.Tipsand Warnings
  • Contact local police departments, hospitals and fire departments to inquire about child car seat safety checks
  • Graco Infant Restraint/Carrier will not protect against serious injury or death if not installed properly. Always read the Graco owner's manual that comes with product prior to attempting installation and travel with an infant.
Jul 19, 2011 • Home
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
How do we fix front passenger side seat belt retractor on 1999 Ford Taurus? It will not pull out....
you may have to remove the bolt that holds the buckle to the floor. Try to push the belt into the retractor and see if it frees up.
I assume you are saying it is in the locked mode. It has an automatic lock mode for holding a child seat. When the belt is pulled all the way out, it goes into locking mode. You will hear it ratchet when the belt starts going back in.
Section 01-20A: Restraints, Active 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Safety Belt, Lap/Shoulder The dual locking mode retractor on the shoulder belt portion of the combination lap/shoulder safety belt for the front seat passenger and rear seat outboard passengers operates in two ways:
  1. In the vehicle sensitive (emergency locking) mode, the shoulder belt retractor will allow the occupant freedom of movement, locking tight only on hard braking, hard cornering or impacts of approximately 8 km/h (5 mph) or more. The front and rear outboard seat belt retractors can also be made to lock by pulling/jerking on the belt.
  1. In the automatic locking mode, the shoulder belt retractor will be automatically locked and remain locked when the combination lap/shoulder safety belt is buckled and does not allow the occupant freedom of movement. This mode provides tight lap/shoulder belt fit on the occupant and on a child safety seat or infant carrier installation restraint.
  1. When the combination lap/shoulder belt is unbuckled and allowed to retract completely, the retractor will switch to the vehicle sensitive (emergency) locking mode.
sxh~us~en~file=ani_caut.gif~gen~ref.gif WARNING: REAR-FACING INFANT SEATS SHOULD NEVER BE PLACED IN THE FRONT SEATS.
The automatic locking mode must be used when installing a child safety seat on the front passenger seat and rear outboard seats where dual locking retractors are provided
Child Restraint Seat
If there is a little ******** the top side of the seat u pull that as u pull on the straps of the restraint seat and they will retract in to the seat but it is easy to do without the child being in the seat
I need to put the straps back in seat
When I was doing research on your problem, I came across this recall. Please read and see if it relates to your product. RECALL ID# 66785 - CHILD SEAT Recall Date: July 28, 1993 Model Affected: AUTOMATE Recall Summary: THE TONGUE OF THE BUCKLE ASSEMBLY CAN CORRODE. THIS DOES NOT COMPLY WITH FMVSS 213, "CHILD RESTRAINT SYSTEMS." ALSO, THE LABEL WITH USE AND SAFETY INSTRUCTIONS IS MISSING FROM THE PLAYSKOOL MODEL. Consequences: BUCKLE ASSEMBLY CORROSION COULD AFFECT THE SAFETYPERFORMANCE OF THE CHILD RESTRAINT. THE MISSING LABEL MAY CAUSE IMPROPER USEOF THE CHILD SAFETY SEAT. Remedy: KOLCRAFT WILL PROVIDE OWNERS WITH A FREE REPLACEMENT HARNESS ASSEMBLY AND INSTALLATION INSTRUCTIONS. OWNERS OF THE AFFECTED CHILD SEATS SHOULD CALL KOLCRAFT TOLL-FREE AT 1-800-453-7673, TO OBTAIN A NEW REPLACEMENT HARNESS ASSEMBLY. Notes: KOLCRAFT ENTERPRISES, INC. Potential Car Seats Affected: 307017
33helpful
6answers
Missing Instruction Manual
https://plweb.evenflo.com/faq_detail.aspx?faqid=4407 the above link is for the manual but here are the instructions. If you have two plastic harness adjusters located on the back of your seat please follow the following steps: On the very bottom of your car seat locate two metal anchors one on each side of the seat, pull the metal anchors out of position and turn them sideways and feed them through to the front of the seat. Release the buckle tongues and chest clip and pull the harness straps to the back of the seat while pushing the chest clips, buckle tongues and harness anchors through to the back of the car seat. NOTE: You may find it easier by pulling down the seat pad when feeding the straps through. All pieces will fit through the harness slots. Choose the appropriate slots for the new harness position. Push the harness anchors, harness straps, buckle tongues and chest clips back through to the front of the seat. Once the straps are completely pulled back through to the front of the seat, make sure the straps are not twisted by clipping the chest clip together and buckling the buckle tongues, then feed the metal anchors through to the bottom of the seat and clip anchors back into place. ********************************************************************* If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of If you have an adjustment strap that is located in between the child?s foot area that allows you to loosen and tighten the straps please follow the following steps: Loosen the harness straps by pressing the harness release button that is located between the child?s legs near the feet area; while pulling on the harness straps from the front of the car seat near the shoulder area. Turn the car seat around and from the back side of the seat follow the straps down to the metal splitter plate, remove the ends of both straps from the metal splitter plate. Once the straps are removed, pull both harness straps completely through to the front of the seat. Choose the appropriate slots for the new harness position and feed both straps through from the front of the seat to the back of the seat. Making sure straps are not twisted; hook each end of the straps back onto the metal splitter plate. Tighten the harness straps by pulling the adjustment strap located on the front the car seat between the child?s legs. NOTE: Final adjustment of the harness straps must be completed with the baby in the child restraint.
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
