Question about Symphonic ST419E TV
Snowy picture on symphonic tv
All I did was unplug the cords to the tv to move it to a different tv stand and the picture is all snowy i cna hear the cable shows and kind of see it. Dont know what happened?
  • barnham Jan 03, 2009
    I bought a used Symphonic tv. While it was on the floor, I hooked the cable to it and it worked fine. I lifted it up to put on top of a dresser and the picture became snowy. I also noticed the power chord got real tight as I forgot to unplug it. Did I mess up the power chord and it's cuaing the snowy picture now? Any way to fix it cheaply?
    Thanks.
    I hooked up another tv and it worked so it's not the cable.
    New Friend:
  • 76 Answers
Check the cable is proper. If it is proper Tuner is faulty.
Posted on Sep 06, 2007
SOURCE:
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
Snowey on scrreen
I've been repairing TV's for over 15 years and I would say either a bad Tcon's or main board issue. Theirs no need to replace capacitors these days, you can get the main board from $40-60.
Have you tried using different devices on the unit? If your getting a snowy picture on a satellite receiver, check with your provider for troubleshooting guide their unit. Or let me know the provider and I can lead in you right direction.
Thanks,
Jason
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
Jun 09, 2016 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My bush 42 plasma tv has a snowy picture
Check all the input connections. Snowy picture cane be due to weak input signal.
Mar 09, 2013 | Televison & Video
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
Picture is really snowy in the bedroom and we have another lg tv in the family room and it has a great picture on it they are both hooked up to the same dish network receiver but it just started like 4 or...
Hello, I hope this was resolved, but if not, here are some steps to run through. It sounds like the tv that is showing only snow is on an incorrect channel and/or input. The correct channel is different depending on what tv it is that is snowy. If TV2 is snowy where there is no receiver box, that tv needs to be on channel 60 or 73. If TV1 is snowy, where the receiver is, then you will want to make sure that the tv is on either channel 3 or 4, and it usually needs to be on an input as well. Anything ranging from video1 to HDMI3. Also, make sure that you have a blue, green, and yellow light on the front of the receiver box. If none of these steps help, unplug the receiver from the power source for about 10 seconds. If this still does not help, or you have any other questions, please e-mail me at [email protected].
Becki Barned
DISH Network Customer Service
Nov 21, 2010 | LG 32LD550 32 in. LCD HDTV
I need help: Snowy picture/Bad convergence problem/Turns itself o
Have you tried the TV in more than one outlet to make sure it is not an outlet power issue?
Apr 11, 2009 | RCA R52WH76 Television
Snowy picture
Usually a snowy picture means that you have a bad ground connection. You should see that some channels are beter than others. Verify that the cable connection is good. Try a different cable if you can. If that has no effect, than we need to start looking at the tuner itself. If you can change channels but just have a poor picture, chances are that a resolder of the tuner section will resolve the problem.
Keep us posted.
Dan
Jul 29, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
Symphonic ST419E TV Logo
81 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
