2003 Land Rover Discovery Logo
Posted on Apr 07, 2009
Cannott open rear door of my landrover discovery 300 series
I have a landrover discovery 300 series tdi 1996. i cannott open rear boot door either from the inside or outside.can you please tell me how to fix it as i need to get it m o t,d to sell the vehicle
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
694
Points
Take off the logo on the rear door and spray some wd40 into the system.
1helpful
1helpful
How do i remove the inside cover to get to the rear brake light on my 1996 discovery landrover thanx
which light are you referring too? Third light on door or one of tail lights?
6helpful
Remove the inside rear door panel for 1995 Landrover
Remove the 2 bolts holding the grab handle ( 10mm) Remove the screw holding the pull handle plastic cover and remove the cover. Use a fork and pry the panel away from the door and you will be able to pull it off. Before refitting, check all of the plastic clips that hold the panel to the door, some will have broken off. Remove them and fit them back on to the trim panel and glue them on. Refit is reverse as removal. Hope that helps
The heater matrix on my 1996 landrover discovery tdi 300, is leaking, and I have bypassed it, however I need to replace the leaking one, and do you have a diagram of how I do this? Thanks. Simon
Hi:
You can usually get basic information on replacing parts that you purchase from the online autoparts stores, like www.autozone.com.
If you need really good guidance to replace your heater core, I suggest purchasing a 1 year subscription to www.alldatadiy.com For Approx $20, you can get step by step info on everything on your vehicle!
3helpful
Rev counter not working on my landrover discovery 300 tdi m regd
check the terminal at the back of the alternator prone for loose connection sqeeze it together and refit it.
2helpful
2answers
Windows
Hi.
I had this problem on my discovery 300 tdi, behind the gove box is a black box bolted onto the small bulkhead if you open this, you will find a circuit board with 2 plugs going into it, this is the ecu for the windows you will find that there will be a dry soldier joint on the circuit board just check this, my discovery had the same problem, re-soldiered the circuit board and all works fine.
If you google for landrover forums you will find the answer on there.
hope this helps.
Top Land Rover Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Land Rover Expert? Answer questions, earn points and help others
