Question about Xerox One Touch 2400 Flatbed Scanner
Reinstalling 2400 scanner driver
Have just reinstalled windows xpro but can no longer install 2400 scanner , installs scansoft paperport 8.0 but keeps asking for xeroPnP driver disc and/or vizmicro.dll.Have tried all sorts of combinations , ie windows hardware installer but rin out of ideas . Any help greatly appreciated. Regards macross
  • 12cooky21 Jan 05, 2008
    my scanner installer won't install...won't open
    Genius:
  • 2,985 Answers
If this scanner was previously used on a Win95/8/ME system the likely hood of it working with and NTFS[3000/XP] system is slim. This is because the two system work in different ways and the scanner design for 95/8 does not recognise commands from a NTFS computer. Two thing to try Go to Mt computer/Help/Compatibility and read it up. then right click on the scanner software and click on properties/compatibility and set it to Win98- see what happens You could checkout Xerox for driver updates also. But don't hold your breath
Posted on Sep 07, 2007
Nuance PaperPort won't install on Windows 7 64-bit Toshiba dual Pentium processors
This problem occurs due to corruption of data on your computer.
You must reinstall the operating system, you have to check the hard disk to eliminate physical damage on it.
Apr 11, 2014 | ScanSoft Nuance ® PaperPort® 11 Full...
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
I have paperport 9.0 and I can't get it to work with Windows 7 which I just installed.
PaperPort 9 is not supported for Win7. You need to upgrade your product or use a Virtual computer running a different OS. PaperPort 10 is being tested with Win7. PaperPort 11.2 and PaperPort 12 are fully supported under Win7. (My household has PaperPort 11. It doesn't work consistently with Win7 and a generic Win7 driver for an older scanner.)
With Win7 Pro or Ultimate, you have the option of downloading and installing the XP mode. (This actually takes two downloads.) Once you are running the virtual XP computer, you can install the PaperPort 9 and the scanner (if you want to capture the files from there). To share images with the real computer, files may need to be stored to external media. Hardware can only be installed to one "computer" and you will be prompted to uninstall the device from the other computer.
I hope this helps.
Feb 19, 2010 | ScanSoft PaperPort Deluxe 9...
It keeps saying that the scanning device is Out of memory/exceeds limits? is this a paperport problem or my scanner? and why all of a sudden? My scanner is a Canon MX860 and has been working great -...
"...till now"
So... what changed? did you install some new software that consumes a lot of resources?
Some update?
Changed something in the resolution? (higher = more memory needed)
check the disk space too, maybe the pagefile is larger than usual.
or, re-install the scanner driver, and PaperPort just to clear things out.
Sep 17, 2009 | ScanSoft PaperPort Deluxe 9...
Issue installing xerox documate 510 scanner using windows vista
Have a Documate 510 Scanner and keep getting the following error message: "out of memory, not enough memory for scanning device". How can i fix this?
Apr 07, 2009 | ScanSoft PaperPort Deluxe 9...
Problem reinstalling Brother MFC 8440D.
uninstall the brother software for this machine, then reinstall the softeware. the paper port some times will install automaticly or you may have to click on iy to indtall. brother tech
Dec 02, 2008 | Brother MFC-8440 All-In-One Laser Printer
Xerox One Touch 2400 Flatbed Scanner Logo
238 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
