When I try to activate archicad 16 crack it says the it cannot access the file because maybe it's in use, but it's not, also after checking in the pc processes...What I have to do to make it work?? same problem with Archicad 13-14-15
Contact the software manufacturer or vendor customer support. The
serial number is normally provided with the software or with the
paperwork at the time of purchase.
The problem is related to the FNPLicensingService.exe service and FNInterface.dll file.
The first thing you can try is open Rosetta Stoneto and kill the FNPLicensingService.exe in task manager. This may or may not give you access to Rosetta Stone.
If that doesn't work, install Rosetta Stone on another computer (your license will allow two machines) then copy the rosetta stone directory from program files to the new system. Then open Rosetta Stone and it should be fine.
Before doing either of these things it's best to delete the c:\program data\rosetta stone\tracking.id file.
If you have a cracked version, make sure your going INTO the file where the cracked application is and pasting THAT into the program file for RS (a window should come up asking if you want to copy and replace, keep both file or whatever if you've done it right.) Do NOT copy the FILE with the crack app in it to the program files this does NOTHING!!
Maybe your activation your your software is illegal. or maybe your installer doesn't really have all the requirements or the needed components to have full the instalation process. try to reinstall your software, but if it doesn't work, maybe you can call your software dealer.
