Question about Mitsubishi VS-70707 70" Rear Projection Television
Once power is off T.V. won't come back on
My 50 inch projector television won't come on once you turn it off. The first time it happen we were watching television then the picture went out and there was only sound. then when the television was turn off it would not come back on until the next day. the problem we found out from the repair specialist is the power board. we need to find a power board for our vs-70707.
    Genius:
  • 1,153 Answers
First CHECK IC700 PIN 20 (AC-OFF) FOR 0 VOLTS DC. IF HIGH, CHECK FOR LEAKY D980 PART # 264P045040 ON THE MAIN PCB. This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Posted on Sep 05, 2007
SOURCE:
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Problemith 50gx30b
You want get information for free but you don't want give information for free?????????????????
Dec 19, 2008 | Hitachi 50GX30B 50". Rear Projection...
Zenith IQC60H94W 60 inch rear projection turns off
Hi
in this complaint you have defective power oscillation! thats why your TV On and Off
Thanks!
Oct 23, 2008 | Zenith IQC60H94W 60" Rear Projection...
Sony wega rear projector
What color does it flash? Also it may be blinking a code so we need you to count the # of blinks it should blink a certain # of times, then pause, and blink that same # of times again. Let me know and I will be able to help you furthur.
Tim
Sep 11, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
MY TV DOES NOT COME ON AT ALL
I have seen this symptom when the vertical output IC has cracked or burned out, and the set is shutting down to protect the CRT's. When you press the power button the computer clicks the main relay and the set powers up, but a fault is immediately detected and the computer shuts the relay off, giving that double click sound. The circuit should be repaired by someone with experience.
Jun 27, 2007 | Toshiba 50H72 50" Rear Projection...
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
Mitsubishi VS-70707 70" Rear Projection Television Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
