Question about Konica Minolta PagePro 1350W Laser Printer
Konica pagepro 1350W
How do you run the cleaning sequence for this printer? I am starting to get a line down the right of page. I may need new toner but I would like to try cleaning first. Is it on the cd? If so, please tell me and i will try to find. thank you
  • netway Dec 27, 2007
    You are using an end-of-lifed (completely used) toner cartridge or a non-KONICA MINOLTA toner cartridge.
    For the best print quality, you are strongly recommended to replace it
  • escalon Jan 07, 2008
    I have replaced toner and used air on the inside, how do you clean the rollers?
There is no cleaning sequence for the 1350w. I usually just pull the toner unit out and clean the roller, etc. Compressed air for the moving parts and hard to reach places. Best to do it outside.
Posted on Nov 15, 2007
Posted on Dec 27, 2007
SOURCE:
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
After a few copies, black lines over entire page.
the toner comes with a drum if you look at the drum you should see black line try to clean it by rolling it forth and back or there is some toner inside the printer most of the time there is a scratch on the drum ,
Aug 19, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
Everytime I print a line appears from the top to
If the line is always in the same spot, it's because of damage to the image drum. In this printer the drum and toner cartridge are in one unit, so replacing the cartridge will fix the problem. New OEM cartridges are around $100, and after-market compatible ones are about $60. Those prices are from a few vendors I found by searching for replacement drums on Google.
Hope this helps. Thanks for using Fixya!
Feb 26, 2010 | Konica Minolta PagePro 1350W Laser Printer
I have a Konica Minolta pagepro 1350W printer. I
Please diregard. Since I was using an aftermarket toner cartridge, I took a chance and bought an OEM cartridge and... voila... it's working fine. Apparently, all I had was a bad cartridge.
Oct 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta 1350w
If you're getting white lines, you are running out of toner, but if the lines are black, I believe the drum is the problem .Remove the OPC drum and check its surface for lines, if there are any lines, you can bet it will be printed on the paper.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Apr 25, 2008 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Dec 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
HELP WITH INK LINES DOWN THE SIDE OF PRINTOUTS
If the line is solid from top to bottom of the page, the problem can be in different parts of the printer. Try a different toner cartridge if you have an extra one.
Jul 25, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
517 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
