Here ya go...
Margins and Tabs
Margins and tabs for both
Type Mode and
Mem Mode are set in
Type
Mode, but can be changed in
Mem Mode when text is recalled for
editing. Margins and tabs are set using the typing scale which appears
on the display in
Type Mode. A blinking cursor indicates the typing
position. The letter “L” indicates your left margin setting. The letter “R”
indicates your right margin setting.
NOTE: In Mem Mode, the margins and tabs used when the text
is created will be saved with the text and recalled with it,
even if they have been changed.
Margins
In
Type Mode, to signal that you are near the right margin, the
typewriter will beep 5 spaces before the margin. In
Mem Mode, the text
will wrap automatically when you print.
Margins are preset depending on the pitch setting, which is the number
of characters per inch. They are:
10 Pitch 12 Pitch 15 Pitch
(Pica) (Elite) (Micro)
Left Margin 12 14 18
Right Margin 72 86 108
New margin settings remain until changed again.
1. Move the Mode Selector to
Type. A typing scale appears on
the display.
2. Move the cursor using the
Spacebar or
Back Space to the desired left
margin setting on the scale.
3. Press
Margin.
4. Move the cursor using the
Spacebar to the desired right margin
setting on the typing scale.
5. Press
Code + Margin. A beep confirms each new margin setting.
6. You can change to
Mem Mode, if desired.
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
