i switch on the machine, everything normal and after about 30 seconds it usually takes water, but it doesn't and the machine just stays with the clock showing the same digits from the start????????
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck
Was this helpful?
Yes
No
Popular Solutions for Bosch 18 in. SRS56L08 Logixx
I have a Bosche Logixx slimline dish washer. For some reason there is no water going in. I have...
(More)
I have a Bosche Logixx slimline dish washer. For some reason there is no water going in. I have checked the water pipe from the mains and there is no problem there but the water is not making it's way into the machine. When I turn the machine on you can hear the pump trying to pump the dirty water away but there is nothing for it to pump. Is there a pump to pump water in? Can anyone help? Thanks
Bosch dishwasher SRV43M03GB/15 3year old First problem would not fill with water changed programme...
(More)
Bosch dishwasher SRV43M03GB/15 3year old First problem would not fill with water changed programme filled with water but now wont rinse
Hi, I have a Bosch Logixx Maxx freedom performance dishwasher and want to know where to add the...
(More)
Hi, I have a Bosch Logixx Maxx freedom performance dishwasher and want to know where to add the salt. There is no screw cap on the floor of dishwasher, as in others. Only a lift up flap, but this seems to be full of water. The 'salt' LED is on. Please help. Thanks
