Question about Coby TF-DVD7060 Portable DVD Player
COBY TF-DVD7060 SAYING WRONG DISC
I recently purchased this portable dvd player and it worked fine, but all of the sudden it started saying wrong disc. When in fact it was the same disc I watched the night before. Can anyone help please.
In Remote Control:
1) Press SETUP
2) Press Fwd (»)
3) Press Rwd («)
4) Press Fast Forward (»|)
5) Press Fast Rewind (|«)
Original region number (1 to 6) will appear - uses arrow keys (Navegation) to change to 255 (ALL Regions).
A couple notes:
- The keys referred to in the above hack are on the remote control (not on the front panel). But, if you want, you can use the front panel to implement the hack – just use the key equivalents (i.e., for SETUP, press Mode twice; for », press and hold »| for 2 seconds, and so on ).
- When the Region Number appears, it is in the upper right corner of the Set Up window without any label. In other words, if your player is currently set up for Region 1, look for the number 1 to appear in the upper-right corner of the Set Up screen (once you've pressed the correct sequence of fast forward and reverse keys). Then use the arrow keys to toggle the number to 255.
If you remove the main battery, you might have to do the trick again.
Enjoy.
Posted on May 04, 2009
SOURCE:
How can I make a movie loaded without it saying Wrong Disc every time?
sorry? what exactly? Movie loaded without it saying wrong disc every time?
Feb 24, 2010 | Coby TF-DVD7005 Portable DVD Player
Coby DVD Player wont play
try running an optical disk cleaner it worked for me but I have to clean often.........a cheap fix if it works.
Jan 26, 2009 | Televison & Video
My coby portable dvd player keeps saying wrong disc
You may need to clean the laser in the unit. You can purchase a cleaning disk at Radio Shack or Best Buy. They are normally less than $20.
Nov 06, 2008 | Coby TF-DVD7107 Portable DVD Player
"another wrong disc"
I too do not understand how to check the motor or change the wire
Jun 29, 2008 | Coby TF-DVD7100 Portable DVD Player
COBY TF-DVD7307 Portable DVD player
anybody can help my dvd player with broken wire connected to the LCD many thanks by [email protected]
May 13, 2008 | Coby TF-DVD7100 Portable DVD Player
Coby TF-DVD7100 7" portable flat screen...keep getting "Wrong Disc" Error
I have seen this problem on several Yamada & Xoro brand DVD players. If you remove the lid after powering down with the disc tray closed and a disc in it you may well find the ribbon cable to the read head is rubbing on the disc. The ribbon cable is held to the base of the box by a sticky pad under a 45 degree bend in it and a piece of sticky tape !!!. Power up unit, open disk tray, power it down, retape cable to base securely with small strips of duct or gaffer tape (using tweezers helps) and hey presto it will work again. The cable rubbing slows the disk spin speed hence "data read error" unit assumes "bad/faulty/wrong type of disk". All that technology screwed up by using a cheap bit of tape in the factory assembly, amazing eh !.
Mark
Mar 02, 2008 | Coby TF-DVD7100 Portable DVD Player
"Wrong Disc"
CHECK MOTOR OR CHANGE THE STRIP WIRE
Mar 01, 2008 | Coby TF-DVD7100 Portable DVD Player
Dvd player just stop working all of a sudden
I have a studio and sometimes certain disc will play on one device and not on another..If you have already played the disc on the device I would try the clean the head. They sell cleaning kits..The DVD player only recognizes it can't play it..they could have it say (Clean disc) but they want you to buy another one..And it could mean its broke...Who knows...Just do all you can do...And a lot of boot leg disc want work...Not saying you buy them...Just saying to help anyone reading this...Hope this helps
May 08, 2017 | Coby TF-DVD7100 Portable DVD Player
Problem
I have also had the misfortune of owning one of these substandard pieces of trash. I corrected my wrong disc error by manually moving the laser towards the center. The laser seems to jump off track and gets stuck on the outer edge for some reason. I'm still battling a software issue that keeps reverting to the set-up screen.
Oct 12, 2007 | Coby TF-DVD7005 Portable DVD Player
Wrong Disc
I work for Coby technical support.
Thanks for using FixYa.
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Aug 09, 2007 | Coby TF-DVD7005 Portable DVD Player
Coby TF-DVD7060 Portable DVD Player Logo
176 people viewed this question
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
