Question about Brother MFC 420CN All-In-One InkJet Printer
Wireless printing I have the new verizon laptop connect card. i want to set my printer up to print wirelessly, how do i do this without having a cable or DSL connection?
You can't. The Verizon card connects only to the Internet.
Posted on Sep 18, 2007
  • 832 Answers
See here: http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000400/000057/faq000457_001.html?reg=eu&c=gb&lang=en&prod=dcp340cw2_eu
Posted on Sep 14, 2007
SOURCE:
HP Photosmart 5520 wont print when pc is connected to router through ethernet and printer wireless
Have you tried a cold re-boot on printer PC and router worth a try first then check all are on-line and communicating Can you use the PC without the Ethernet cable or a direct cable to the printer just to set it up (Re-set up).
Regards David, more info may help all the bests.
Ps. my old HP is a pig at time but I never have to use the cable which is a good job as I can never find the thing...
Dec 25, 2017 | HP Photosmart 5520 e-All-in-One -...
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Hello, How do I connect my Epson stylus PHOTO px700 to my laptop?
NETGEAR’s 54 Mbps Wireless Print Server with 4-port Switch allows you to connect one or two printers to your existing wireless network, without using unsightly Ethernet cables. Simply place your printers anywhere in your home or office that works best for you, plug them into the print server’s USB ports, and the Smart Wizard set-up function automatically guides you through configuration. Then you can send your business documents to a high-end color printer, and your kids’ homework to a black-and-white printer. The print server also acts as a wireless Ethernet bridge, connecting a cluster of up to four PCs and laptops without requiring dedicated wireless adapters. I t employs powerful WEP Encryption and WPA-PSK to keep your wireless network secure, and interoperates with all standard b and g wireless devices. All this in a sleek, space-saving stand-up case.
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Dell 948 wireless printer
hi,
u need to have wireless internet connection, first uninstall the printer sw, while reinstalling choose wireless install, follow inst, connect the printer, configure wireless adapter by choosing the correct wireless nw and by entering the security key(WEP, WPA), if wireless adapter not detected then, unplug all cables from back of printer,removed wirless adapter, press power button for 20 secs without any cables connected, connect cables, restart printer, connect the wireless adapter, u will get msg nw card detected, then try reconfiguring by entering the correct keys, in case if u dont know the security key contact ur internet service provider, once correct details are entered it will configure successfully, unplug usb cable from printer and pc, install printer sw, issue resolved, if there is no communication then check the firewall settings, anything relating to printer give full access, restart pc, try printing,
ps: if usb cable is connected to printer the nw card will be disabled.
Nov 03, 2008 | Dell 948 All-In-One InkJet Printer
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Printer only prints rarely
This is going to be with a setting, either on the printer or the laptop. It's most likely with the laptop, in that the wireless connection with the printer isn't there. Make sure that the laptop is recognizing or seeing the printer at all times. Check the software program for any type of sync setting between the two. The Geeks have a tenancy to forget that not everybody is as computer savy as they are and will do some minor little adjustment, like synchronizing, and not think to let that person know about it, or won't tell about it in order to get back in the pockets of the person. If you still can't get it to work, I suggest calling a small computer shop in your area, they treat you better and they'll be a whole lot cheaper. For example, I do house call trouble shooting in my area for $50 or less, depending on the situation.
Jul 30, 2008 | Dell Inspiron E1505 Notebook
Printing wirelessly to a Canon MP600
1) you need it to print from a laptop if you do not want to have to set up another computer, and mobile phone have bluetooth buit in
2) YES
3) set up the printer on another computer, and set it for sharing. Then make sure that you laptop is recognized in the network connections wizard, then on the laptop select add new printer and select the bullett that say a network printer. the rest is pretty easy, select browse for a printer or something, it is the first option, select it, say yes to all dialogue boxes, and let the computer do the rest.
EASY PEAZY LEMON SQUEAZY
Feb 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
191 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
