Question about Polaroid i532 Digital Camera
Polaroid i532 digital camera
Help! I just need to replace the usb cable on my polaroid i532 digital camera, and can't seem to find the correct one.
  • Anonymous Nov 04, 2007
    I have a Polaroid i532 digital camera and my son threw out the box containing the CD and cables for the camera. How do I go about replacing them. I have photos i want to download.
    thanks Karen
Try this web site. Address is long so it will be easier to copy and paste to your browser.
TS
http://www.pronto.com/user/search.do?displayQuery=polaroid%20usb%20cable&SEM=true&query=polaroid%20usb%20cable&adid=1191890699-8492786-0_ys&ref={keyword}&creativeid={creative}&site={placement}&OVRAW=Polaroid%20i532%20USB%20Cable&OVKEY=polaroid%20usb%20cable&OVMTC=advanced&OVADID=10398541512&OVKWID=127534345012&loadingComplete=true
Posted on Nov 03, 2007
SOURCE:
How do i upload the pictures from my i532 polaroid camera?? i need help asap
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Mar 01, 2011 | Polaroid i532 Digital Camera
Polaroid i532 driver downlod windows xp
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (http://picasa.google.com ).
Sep 25, 2010 | Polaroid i532 Digital Camera
I dropped my Polaroid i532 and now the lens wont
hi,
You must get your cam serviced... due to **** your motor (which operates lens movement has stop working. or the lens has bent and therefore stucking..... taping lightly near the lens may help you... The common reason for motor not working is loss of power connection....
Hope this has helped you..
Please rate the answer...
Thanks....
Jul 07, 2010 | Polaroid i532 Digital Camera
Unable to transfer pictures form i532 polaroid. have replaced usb cable with another, no luck. pc not recognizing it. camera is about a year old. I have pics from our summer vaca in aruba :(
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Aug 09, 2009 | Polaroid i532 Digital Camera
Pictures are not uploading
It may be that the connector inside your camera is de-sodlered from the circuit board, as this connectors are very tiny and the solders too, refering to the USB cable and effort to insert / extract it.
Or if you are lucky, just th USB cable out of order, did you try with an other cable ?
I encountered this desoldered connector on the camera of my father, I arrived to re-solder it once (very difficult as pins are less than .2mm from each other), but it deos'nt hold very long.
To be sure, when USB cable is connected, try holding it pressed gently to the direction of the circuit board (generaly to the direction of the back or to the face of the camera), if you arrive to connect (PC will show the opening window), this is it.
No sheap solution to repair it, But you could always use your camera end dowload your pics with a card reader, just have to extract the card from the camera and put it in an universal reader, you faind it anymhere on the net at low prices.
Generaly speaking, you should best use a reader with the card out of the camera, and keep the direct connexion with USB cable to the camera for absolute necessity, as this connectors inside the camera are fragile.
Hope it will help, feel free to feed-back or complete.
May 14, 2009 | Polaroid i532 Digital Camera
I was given a Polaroid i532 digital camera to download photos from but I don't know how to do it.  do not have a manual.  please help.
You would first need to load the software to the computer so the camera would be picked up when you attach with usb. The computer will automatically detect and connect the camera. You will be prompt for the function you wist to perform, which is pretty straightforward
Jan 19, 2009 | Polaroid i532 Digital Camera
New memory card now my camera won't turn on?
most likely,if you cant format the card,and the camera doesnt see it,the card is not compatible with the camera.
Dec 18, 2008 | Polaroid i532 Digital Camera
Lost installation CD
Do you really need the Polaroid software?
Jun 23, 2008 | Polaroid i532 Digital Camera
Cameras Logo
225 people viewed this question
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
