Question about Linksys Wireless-N WRT150N Router
Loss of wireless capability of the router
My Linksys Wireless WRT300N has just lost the wireless capability. It just simply stopped broadcasting a wireless signal. I have tried to change the channels but that doesn't work HELP
  • Tod7763 Sep 06, 2007
    Hello Dikla, a little more detail might be helpful. This WRT300N is connected on the access side to a modem which is connected to our internet provider
    On the the internal side, we have two RJ-45 (LAN) cables connected to the router; these go two two 26 port switches that connect our 30 employees' computers. That part works fine.
    It is just the wireless portion of the router that doesn't work. It simply does not broadcast a wireless signal. This is a Linksys router problem, I think. It doesn't have anything to do with what lines are coming in or out of it.
LOST MY CD SET UP TO MY WIRELESS ROUTER WRT300N
Not really required. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Nov 03, 2012 | Linksys WRT300N Wireless Router
I have lost the installation disc and need to reload onto computer is there anyway?
Try here:
http://drivers.softpedia.com/progDownload/Linksys-WRT300N-Driver-Download-21917.html
Aug 02, 2011 | Linksys WRT300N Wireless Router
The router works for computer hardwired to the unit but none of the wireless computert, etc. can find a the network connection
Here is the official support site for your router make/model which should help you greatly:
http://homesupport.cisco.com/en-us/wireless/lbc/WRT300N
Most likely, you will have to login to your routers Administration page and go to the "Wireless" Settings area and make sure that Wireless is turned on and that the SSID Broadcast is also on. Also, make sure your router is within a reasonable distance from the PCs/Devices you're trying to connect wirelessly.
I hope this helps :) I'm sure it will. All of your answers should be available from the link I provided above.
Best of luck! Have a great day!
-James ;)
Dec 18, 2010 | Linksys WRT300N Wireless Router
I lost the cd to install my wireless router. I also do not know how to hook it up to my modem
You can get the install program from Linksys http://www.linksysbycisco.com/APAC/en/support/WRT300N/download
There are a bunch of settings so I have included the highlights of what you want to address:
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping to bottom of the router. Physical access is not the security issue.
4. Check that your router is set to broadcast its' presence.
Dec 05, 2010 | Linksys WRT300N Wireless Router
Linksys wrt300N wireless light not blinking
the wireless connections says limited or no connectivity when it does not get IP address from the router.
There might be problem with the wireless settings of the router.
if your network is a secured network then you will need to check the network key.
You can try to upgrade the firmware of the router. that will be a good option.
Click Here for step by step solution
Oct 29, 2009 | Linksys WRT300N Wireless Router
WRT300N is no longer detected
Hook up your ether cable to a port other than the WAN port.
Type this into a browser...
http://192.168.1.1
Linksys WRT300N Wireless Router. ... Default IP address: 192.168.1.1
Oct 01, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300n will only allow local access wirelessly
go into the router interface and see if it is set for DHCP and reboot systems it should be fine
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 17, 2009 | Linksys WRT300N Wireless Router
Try going to the configuration page and check if it is sending a wireless signal.
Dec 24, 2008 | Linksys WRT300N Wireless Router
Linksys Wireless-N WRT150N Router Logo
154 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
