Question about Canon imageCLASS D780 All-In-One Laser Printer
Document feeder After copying about 400 pages one day, the feeder will no longer feed sheets. Any suggestions???
    Problem Solver:
  • 19 Answers
Try clean with alchorol those rols what feed those sheets. I'm sorry my English . But try clean. or some think stuck the paper on tray Aleixo
Posted on Sep 05, 2007
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Ricoh C21SF Automatic Document Feeder (ADF)
Take a little soap and a little water and clean the gray feed tire that is located in the document feeder. Check for any paper obstructions. If the machine has had a lot of prints I would replace the feed tire.
http://www.websitetoolbox.com/mb/copierquestions
Sep 25, 2008 | Ricoh Aficio SP-C210SF Printer
I am trying to copy a document from the automatic feeder. The feeder will not pick up the document and instead of getting a copy, I get a blank page. I have cleaned the rollers and nothing has changed.
I have noticed that these rollers can wear to the point that they no longer make proper contact with the paper regardless of cleaning. (Especially if you frequently print to paper of varied thicknesses) Try using a card stock sheet in the automatic feeder, if the problem goes away, you will need to replace the rollers to print to standard letter.
Aug 22, 2008 | Office Equipment & Supplies
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Problem with Automatic Document Feeder
There maybe a small piece of paper stuck within the feed path check this as it is all sensors so the machine is giving a reading that there is a jam or place a original on the feeder and press the copy button as you may of had a jam and the machine is asking for the original to pass through it again.
I suggest the first one though
Thanks J
Jan 11, 2008 | Sharp AL-1551CS Printer
Canon imageCLASS D780 All-In-One Laser Printer Logo
112 people viewed this question
Clive
Clive
old marine
old marine
