Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
LCD backlight lamp broken
The picture on my LCD flip-out monitor on my SONY DCR-HC40 is very dark. I think the backlight lamp is broken. I am considering trying to replace the backlight lamp by myself as a repair charge has a minimum fee of $150+. Can anyone tell me if it is easy to replace the lamp and if so, direct me to instructions on how to replace one?
  • Anonymous Mar 21, 2009
    i have the same problem and i actually thought it was just broken till i heard of this problem, i then took a closer look and sure enough its just too dark
    Champion:
  • 288 Answers
Don't do it. $150 is good price
Posted on Sep 18, 2007
SOURCE:
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
The screen fades out sometimes and i have to wiggle it to get it back. i have a sony vaio vgn-cr115e
www.ladparts.net
Oct 19, 2009 | Sony VAIO VGN-CR115E/P Laptop
DCR-HC40 LCD works, but Touchscreen doesn't. I was able to calibrate once -- but din't hold settings. I cannot calibrate.
hello its ruttine problem ,just change the lcd FLAP and you can use the touchscreen.its not to wory about that
Aug 25, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony vio pcg7z2L
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | Sony Computers & Internet
Problem with dark LCD screen and accessing the the LCD ribbon that I think is loose
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 10, 2009 | HP Pavilion dv1010us Notebook
I have a broken monitor. where do i buy a replacement acer notebook?
Visit eBay.com and do a search with the exact make and model. There are several listings, and several prices. The hard part is doing the actual replace. And... next time you need to hide the laptop don't sit on it!
Apr 15, 2009 | Acer Aspire 5050-3242 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Picture flickering with dim display.
Apr 07, 2009 | Acer Aspire 5040 Notebook
Document for downloading to laptop form sony handycam dcr-hc40
Check all updates and helpful news about DCR-HC40 on Sony Support.
You will get answers of many questions about this camcorder.
Jan 04, 2009 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
264 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
