Sunforce 2500 Watt Pure Sine Wave Inverter 11260 Logo
A
Anonymous Posted on Aug 16, 2013
I recently bought a Sunforce 2500 watt pure sine wave inverter. After two uses, attached to a 12-volt battery, the AC stopped working. I'm still getting power from the 12 volt plug. I tried two different batteries but the problem was the same. The lights don't even come on. Hitting the re-set button doesn't help.
2 Related Answers
Anonymous
  • Posted on Nov 01, 2009
SOURCE: The Sunforce 2500 pure sine wave inverter displays
Went to a free website with industry professionals sharing their knowledge instead of signing up for more ways to spend what little money I have.
Anonymous
  • 643 Answers
  • Posted on Jun 28, 2011
SOURCE: The Marine deep cycle Battery
Did you check The fuse can be found in the 12V DC barrel connecter
I have a 24 volt 5000 watt pure sine wave inverter that keeps tripping. It has 28.6 volts going in from the battery and 115 volts going out at 8 to 12 amps any suggestions.
It sounds to me that you have a load that draws too much from time to time. If the inverter will run without a load without a problem, try adding loads one at a time until it starts to trip off. That should give you an idea as to what the problem is. It could be that there is a problem internal to the inverter that causes it to trip prematurely..
tip
WHAT IS A POWER INVERTER?
A power inverter is an electronic device that converts electricityfrom one form to another. Power inverters have become more popularrecently as the technology has become more efficient and much moreaffordable.
The most popular use for a power inverter isconverting battery electricity into mains electricity. For exampleconverting your car batteries' 12 volts DC into mains electricity 240Volt AC (Australia) or 110 Volt AC (USA).
WHAT POWER INVERTERS WILL HELP YOU DO
  1. Power inverters enablemains operated electrical equipment to be used even where there is nomains outlets, like in your car, caravan or even on your boat!
  2. Powerinverters bring creature comforts from home when you go camping orcaravaning allowing you to use your TV, fridge or electric shaver infact most of the normal mains powered conveniences from the home.
  3. You can charge your laptop in the car even if it doesn't happen tohave a 12 volt adapter. In fact a power inverter can be a very handygadget just to have in your car for those times you need to use a mainspowered appliance while you're away from a power socket.
WHAT TO LOOK FOR WHEN BUYING A POWER INVERTER
Apartfrom looking for a good quality well priced product there are a coupleof important elements to consider when selecting your power inverter:
HOW MUCH POWER IS ENOUGH ?
Powerinverters come in a range of power capacities so selecting the rightone for you is very important. Your power inverter needs to be able toprovide sufficient power for the equipment you want to use it with.
Here is a brief check list:
  1. Check the power consumption for the device you want to power
  2. Allow an additional 20% free board
  3. Add the power for all the devices you want to run at the same time
Note also that devices with induction electric motors like an power saw mayrequire 3 to 7 times the operating power when they start.
Usingan under-powered power inverter may damage it or the appliance you aretrying to use, so be sure to check the specific wattage requirementsand operating instructions for appliances / tools to be used.
PURE SINE WAVE INVERTERS
Normal mains power is known as Alternating Current (AC) and is a sine wave shape like the black line in the drawing below
Pure sine wave (black) versus modified sine wave (red)
Atypical power inverter produces a 'modified sine wave output' like thered line in the drawing above. While this works for most appliances,light dimmers, variable speed drills, sewing machine speed controls,some laser printers etc. will not operate correctly with a modifiedsine wave power inverter.
Pure sine wave power inverters areespecially designed to provide a more accurate sine wave output and socan be used with these appliances, but unfortunately they are moreexpensive.
Check with your with appliance manufacturer or itsspecifications to confirm if you can use a conventional power inverteror will need a pure sine wave inverter.
WARRANTY
One of thegreat things about electronic equipment is there is no moving parts(although there is a fan in some models) so you can expect a longserviceable life from a power inverter.
STANDARDS
Powerinverters generate dangerous mains voltages so ensure the product youchoose is approved for use with your mains voltage and supplier.
Powerinverters can also generate electro-magnetic radiation that caninterfere with other electronic equipment such as radios transmittersetc. Check for compliance with relevant standards such as C-Tick etc
SAFETY
Powerinverters can generate potentially lethal voltages so the utmost ofcare should be exercised using them to avoid accidental electrocution.
SUMMARY
To select your power inverter carefully check the power requirements for the appliance(s) you intend to use it with.
  1. Start power - Allow up to seven times for an induction motor
  2. Operating power - Allow a 20% margin
  3. Pure or modified sine wave
on Mar 04, 2010 • Electronics - Others
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
1helpful
Hi I have the Sunforce 1000W Pure Sine Inverter and everything was working fine until yesterday the remote stopped working. The inverter is about a month old and the remote has healthy batteries, I tried...
Have you tried removing the batteries for a minute and unplugging the main unit for the same amount of time together. The idea is to fully clear any settings that might have gotten hung up.
1helpful
Can this model be used on the grid? If not, is there a sunforce inverter that can be used on the grid?
If you meant for the mains supply then it must be connected in series to the load so that in absence of power the invertor takes over and when there is power the supply takes over as it charges the battery.
So have this wiring done with the connection routed from the fuse box or main board.
Have recently purchased a Sunforce 11264 4500W true sine inverter, shipment pending. trying to find a view of the back side of it to determine the 12V service connections needed, PDF of manual indicates a...
Hi , i'm sorry but i dont really understand your question , assuming the current draw is around 45 amps then 2 /0 GA is fine , just keep your leads from your panel nice and short , the connection kits are sold by sunforce and there plenty of suitable connectors on the market
example link below
http://www.globalepower.com/Datasheets/BatteryConnectors/BatteryGlobal.pdf
2answers
SunForce 2500w pure sine wave converter add on
Mixing different AH rated batteries, different ages of even the same type battery is a bad idea. The new batteries will be effectively reduced to the equivalent of your worst battery.
Top Sunforce Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Sunforce Electronics - Other Expert? Answer questions, earn points and help others
