Question about Sony Ericsson K800i Cellular Phone
Bluetooth Handsfree Problem!
Hiya all, recently upgraded to a K800i, love it so far, but my bluetooth handsfree does not work, it just doesn't get recognised, doesn't pick it up, the hansdsfree is a Mototorola H350, and it says it is compatible. Thanks all, very much appreciated! x
  • aalin Jun 10, 2008
    K800i
    Brigadier General:
  • 7,752 Answers
Hopefully when you switch the BT headset on the light on the HS comes on make sure that you BT on the phone is on and set to visible.
Posted on Jun 08, 2008
SOURCE:
Can I fix my phone to a supertooth hands free kit
1. From OFF, press and hold the On/Off (8) button for 10 seconds until the Bluetooth Indicator (4) turns blinking red/blue.
The handsfree kitis now in pairing mode.
2. While the handsfree kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function and execute a
Bluetooth search. (See your phone's manual.)
3. When the phone displays the list of Bluetooth devices, select ST
BUDDY.
4. If the phone asks for the password/pin code, enter 0000 and pressOk.
5. The handsfree kit is now ready to use.
Jan 04, 2018 | Radio Communications
I tried my best. bt i couldnt connect my nokia n73 with bluetooth handsfree...plz provide me solution for this...how to connect...
in most nokia N series, you will have your handsfree device paired to your cellphone. it also depends on your handsfree model. some bluetooth handsfree models are not compatible with nokia N series. Jabra handsfree models are compatible with nokia phones. best buy.
Nov 01, 2010 | Cell Phones
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • From the Menu screen, select Settings
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Dec 31, 2009 | Sony Ericsson K800i Cellular Phone
How to connect my nokia BH-104 bluetooth handsfree to N73 mobile
Most handsfrees need you to hold the on button for about 10 seconds to trigger the pairing. Hold the button until the indicator flashes rapidly.
Oct 03, 2009 | Logitech Bluetooth Wireless Talking Kit...
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
Bluetooth Connection to Mazda Handsfree Is No Longer Handsfree
hi,
bluetooth connect is only going to work for up to 30ft in distance so if you go to far from the car it will disconnect because it lost the bluetooth signal.
please rate me. thank you.
May 20, 2008 | Motorola Mobility RAZR V3
Bluetooth handsfree connectivity
Bluetooth handsfree profiles are needed by N 72 which is missing by default in N 72 you will have to install bluetooth profiles. Please refer to nokia website for details on how to install bluetooth profiles
Dec 26, 2007 | Nokia N72 Cellular Phone
Delete/remove pairing
Turn off the bluetooth, then pair up to other devices, or look in other bluetooth devices menu and connect to the device you require
Jan 11, 2007 | Sony -Ericsson OEM HCB-300 Bluetooth...
Sony Ericsson K800i Cellular Phone Logo
96 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
