Question about Mitsubishi MSH09TW Air Conditioner
Blower fan will only work in low speed
I changed the battery to the remote and the high speed of the blower stayed the same... I did unplug the low voltage wiring to the board and the fan started blowing in high and after 5 seconds it turned off.. help please!!!
  • 1,420 Answers
Sometimes after you replace the batteries in the remote, there is a communication disruption between the remote and the wall hung evaporator. With fresh batteries installed, take a paper clip and press in on the "reset" hole located on the remote. Yes you will have to reset the clock but it may help your situation. Then you will need to turn off both the inside unit as well as the outside unit. You must first turn back on the outside unit then the inside unit. If it continues as you have described, it could be a relay on the Main PC board and the board will need to be replaced. If all other functions and modes work, you will probably not have to replace the Receiver PC Board.
Posted on Sep 06, 2007
Blower just started staying on - furnace has been turned of for 6 months
This is a diagram of a blower relay and a fan motor, the normally closed fan relay switch goes to the low speed which is the Heat speed, the low speed is controllled by a temperature delay depicted in the low speed circuit.
The normally open fan relay switch goes to the high speed, which is the AC modes speed , also if you run the fan continuously via the fan switch on the thermostat this is also to high speed.
I suspect the temperature delay's on setting is being reached thus cycling the low speed of the fan.
Nov 08, 2015 | Heating & Cooling
Have a 2009 Nissan Quest I can't turn the heat off. Just stays on a high level of blowing out heat .
If you have a fan that has different speed settings (1234, or low med high etc) and the only one that works is high - then the blower resistor pack has failed. If you have a climate control unit (where you just pick a temp you want) then the fan is controlled by the heating system and it sets fan speed. If you have climate control style try lowering the temp to a lower setting (current temp in vehicle) and see if fan slows down. If not then climate control unit or fan resistor bad. If dial type and you get nothing on lower settings (only high works like mentioned above) you need to change blower resistor. It is located under dash near the fan itself. Look for small unit bolted in duct near fan with wire plug going to it.
Feb 23, 2015 | Nissan Cars & Trucks
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Fan control switch only works on high
If you blower fan will only work on high know that most blower motors are power by a basic electrical circuit that utilizes a multi resistor or a solid-state resistor to control different fan speed modes (low, medium low, medium and high). If the resistor malfunctions it may lose one or more of the lower fan speed settings. First check the fuse and change if needed. If that doesn't fix things change the resister.------------------------------------------------------------------------------------
Launch CResetter Oil Lamp Reset Tool
Mar 07, 2013 | Cars & Trucks
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
I want to change the blower speed
To change blower depends on Make of unit. Most of the time at the fan relay you will Red low Blue med Black high. Only one will be used theother taped off. Just unplug one plug the other one in. Some motros have speed taps on the motor you unplug one wire and plug into the speed you want. Rus
Dec 05, 2009 | Refrigerators
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Mitsubishi MSH09TW Air Conditioner Logo
102 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
