Question about Sony Ericsson T610
Bluetooth Got a T610 secondhand. When I turn on Bluetooth I can connect to other phones and send the other phones pictures, tunes but connot receive any data I have looked and turned off any diverts. HELP WHAT IS WRONG?
  • 91 Answers
Early SE phones had a very odd bluetooth protocol. Its common that it can send different kinds of information but not recieve. Since newer phones are not that reverse-compatible as we would like them to be. I'm not sure that there is any solution to your problem. Sorry
Posted on Oct 05, 2007
How do you pair a jawbone to a samsung t259 phone?
To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Jun 15, 2011 | Cell Phones
I'm trying to send pictures from my NOKIA 2600 classic phone via bluetooth to my computer, but it never connects. "subscribe packet data first" pop out whenever i try.
Kindly try and configure once again.
Open phone settings and select bluetooth to be ON.
Now open the bluetooth manager in the PC as the phone will be identified .. set passcode.
Now open the images to be send and select the mode as bluetooth.
It will be send and received in the bluetooth information exchange manager in the PC.
Apr 19, 2011 | Cameras
Won,t send or receive pictures lg 290c
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem. Hope this information assisted you!
Jan 10, 2011 | LG Cell Phones
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
application.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
I am having problems getting pictures send to my Blackberry 9000 via Bluetooth from Nokia and other phone devices. Even though the device is paired with my Blackberry sending pictures fails (with error...
hey hi...may b i can solve ur problm...
1st open d media application,then lighlight the picture folder by putting the cursor on it.next click on the menu of the picture folder.....there u will find a option "receive through bluetooth".click on that.ucan receive ur files nw.
(Note:-u mst 1st swith on ur bluetooth and must have paired wid the device 4rm which u wish to receive data)
only after clicking on the "receive through bluetooth" the data must b send 2 the blackberry.....
hope u got it....
u can contect me at zeebonbarua@gmail.com 4 quarries..
gud luck
Aug 03, 2010 | RIM BlackBerry Bold 9000 Smartphone
How can i can transfer my photo in cellphone to
1. Get your cell phone software first, install it on your computer, now connect your cell phone with data cable on computer. Now you can easily transfer your picture, sound, video (everything) to your computer.
2. You can also connect your phone via bluetooth. Adjust bluetooth device on your computer. On your phone bluetooth and easily connect your phone with computer. Now send and receive data from your computer and cellphone.
Jan 17, 2010 | Cell Phones
My mobile is nokia 6085 has aproblem in its bluetooth, the bluetooth send data to other mobiles but can't receive any data from the other mobils
it's simple,just turn visibility option to shown to all in your bluetooth option,but take care to turn of bluetooth after complition to make safe your mobile from viruses
Dec 07, 2009 | Nokia 6085 Cellular Phone
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Sep 25, 2008 | RIM BlackBerry 8700c Cellular Phone
I am unable to send or receive photographs on my samsung z400 mobile phone
You can transfer or copy photos using the data cable provided when you bought the mobile. Check your bluetooth settings if you are not able send or receive data using bluetooth.
Apr 04, 2008 | Cell Phones
Cant open pictures
I think you will find you need GPRS & MMS settings for your phone. I don't have the settings but mobile netowrk you use should supply them as a sms message for you free. Hope this helps
Oct 01, 2006 | Sony Ericsson T610
Sony Ericsson T610 Logo
20 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
