Question about Seiko Smart Label Printer EZ30 InkJet
Sieko Smart Label Printer intercepts test prints to LPT1
Trying to print a test print via the properties window on an HP Laserjet 4000 and everytime a window pops up that says "Seiko Smart Label Printer" Printer test page completed! I was never printing to that Smart Label Printer but to the HP Laserjet 4000 on LPT1, smart label printer is on USB.
3 Suggested Answers
SOURCE:
  • 232 Answers
SOURCE: how do I export from outlook to my seiko 440 smart printer
I'm not familiar with this printer but usually you export details as a .csv file which you can import in to most other software packages. If you need more help, please can give more detail. Thanks :)
Posted on Dec 12, 2009
SOURCE: Smart LabelPrinter Seiko 440
These printers are designed to use only the labels with the ink bar on the back. the ink bar is the guide that tells how much to print.
Posted on Oct 24, 2011
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
Hi , We're trying to print the file to TLP 2844 using DOS commend : copy test.txt LPT1 , but the printer does not response . We installed the out-box driver and make the driver pointed to LPT1, It...
the only thing I see missing is the ":" after lpt1
ie - command should be copy test.txt lpt1:
you could also try using print test.txt
or type test.txt > lpt1:
Mar 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
How to use HP Laserjet 2300 dn offline. This printer is a network printer
Thank you for contacting FixYa with your inquiry.
This printer can work very well via a standard printer cable directly connected to your computers LPT Terminal. Most of Microsoft's current Operating Systems already have the LaserJet J2300 drivers built in and will automatically install when connected.
To confirm your connection to go to your computers printer setup and ensure the driver is configured to print from LPT1 port and click on print a test page. (Start/Settings/Printers/LJ2300 - Right Click on properties then click on the tab for ports. The general tab should have a button to print test page)
The network card that comes with your printer (Jet Direct Card) will not be used with this method nor will the Ethernet cable be required.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 14, 2010 | HP LaserJet 2300dn Printer
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
HP laserjet 4L will not print from Windows Vista
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25486&taskId=115
Here is all the documentation that I could locate reguarding this issue. I don't see a driver for Vista....however you should be able to install or run in compatibility mode.
Sep 23, 2009 | HP LaserJet 4L Printer
Printer sends out 'file details' page everytime I print a file
Program/software you use to print? File details can be found at printer properties/printer setup. Disable File Detail/File Information.
May 30, 2009 | HP LaserJet 4000 Printer
Printing problem
The printer itself is printing, but when I stalled Laserjet 4000 and try to print it shows ERROR even printing test page. I do not know why my HP laptop Vista cann't recognize the printer!
Thanks,
Iyaad09
Nov 23, 2008 | HP LaserJet 4000n Printer
PRINTER WONT PRINT
If you has been connected your printer via USB be sure that the printer port is "USB Virtual Port" and NOT Lpt1
Oct 07, 2008 | HP LaserJet 4000tn Printer
HP LaserJet 1320 problem
For this you first uninstall any previous Driver. Install the Drivers after restarting your system. After Installing the drivers connect the Printer. Note down now the Driver must be automatically work because HP1320 is a plug n play Printer. If not change the cable used to connect the PC with Printer and if the Printer is auto detected, you will be able to print the Test Page or any other page.
Feb 12, 2008 | HP LaserJet 1320 Printer
Printing
Is the printer connected via USB or a printer cable to the LPT1 port? Make sure the Port setting in the properties of the printer are set to the correct port. If the printer is plugged into the USB port but the properties say it is on the LPT1 port. the cpmputer will think it is sending something to the printer but the printer doesnt know it.
Apr 03, 2007 | HP DeskJet 940cxi InkJet Printer
Seiko Smart Label Printer EZ30 InkJet Logo
98 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
