Question about Olympus Camedia D-435 Digital Camera
Can't change image size
I need to change the image size from the highest to 640 x 480. Do not want to take pictures at the higher setting
    President:
  • 919 Answers
To change the image size in your camera to shoot at a lower setting - have the camera in shooting mode - go to Menu - go to the symbol that looks like an arrow pointing to the left - Press Ok - then select which record mode you want and press ok.
Posted on Apr 07, 2009
SOURCE:
Hi there I just bought a Polaroid two instant print camera but the quality of pics is really poor very washed out and even a bit blurry do I need to set it up?
set your pixel ratio to the largest setting, this means less pictures per memory, but higher picture quality. Also if possible adjust your iso to the highest setting, as well as the shutter speed, having both of these settings set to the highest point will require more light for picture taking, however will result in the highest quality image.
May 05, 2011 | Polaroid Cameras
I need to know how to increase the size of the pictures to at least 100 for publication in a magazine, the camera is a Lumix DMC-FS42
You have to set the camera for high resolution images BEFORE you take the pictures. If you try to make them bigger later (in a computer, you can't do it in camera), you will get fuzziness or blockiness.
I don't know what you mean by "100". On my Lumix, the picture resolutions are given in pixels, like 2560x1920 or 640x480. The larger numbers are the higher resolutions, and for best quality (and biggest native size), you will want the highest resolution available in your camera. You will also want to set the compression to the finest setting. These settings are on the REC settings screen, which is the first to come up when you press the menu button.
Higher resolution/quality photos will require more storage space in memory, so you might want to get another or a bigger memory card.
Dec 28, 2010 | Cameras
I have a sony 8.1 cyber shot. Can I take a photo with higher resolution than 72 dpi? I can't figure out how to change the setting.
In simple words select higher mega pixel value...
All the settings are not available in all shooting modes.
But in programmable mode find out settings viz."Image Size". By setting this at highest value You can get which you are looking for.
Apr 29, 2010 | Sony Cameras
Photo resolution
Sony H1 takes photos at 72 dpi by default. But the picture quality will be good. if you want to convert it to 300dpi open the picture in adobe Photoshop and select image size and change resolution to 300 dpi. but the file size will be very high to up load. if you want to reduce the file size select the image size in adobe photoshop and reduce it according to your requirement. if my solution proves good please rate it. Regards.
Feb 04, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Lack of mb in photos
If you have your camera set to take the highest resolution pictures(8 MegaPixel), but save in jpg format, then 3 - 4 MB is a normal size for the image file. There is nothing wrong with your camera.
If you have your camera set to save in RAW format, the image files will not be compressed and MUCH bigger. However you will need software that will be able to manipulate images in RAW format.
Jan 07, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
OLYMPUS FE-340/X 8.0 MEGAPIXESL
Hey bljack,
There are two main causes of grainy images with digital cameras. The first cause could be that the image size is set too low. I would have it set to the highest size and quality possible, because you can always reduce an image size but you can never make the image size bigger. A list of the possible image sizes are on page 21 of your camera manual. The next main reason for digital noise is having the ISO set to high. ISO is the sensitivity of the digital sensor, and the higher the sensitivity the more digital noise that will be in your images. I would very rarely have the ISO set to higher than 400. I have provided a link to the camera manual below. I hope this helps!
http://www.olympusamerica.com/files/FE-320_FE-340_Instruction_Manual_EN.pdf
Sincerely,
Allan
Go Ahead. Use Us.
May 28, 2008 | Cameras
Need higher resolution by tomorrow
For the best resolution, use your FUNC button at the back of your camera. Scroll down on the left hand side to the bottom of the menu which starts with AWB, Set your size of image to 3264x2448 and then using the SET button, select S, which is superfine
Feb 14, 2008 | Canon PowerShot S5 IS Digital Camera
How do I setup the camera to save pics above 180 dpi resolution?
Select image>image size, make sure that the 'resample image' box is unticked and change the resolution to 300 dpi. This will automatically change the image size.
Sep 14, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Features of each record mode
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Features of each record mode...
The details for each record mode are as follows: RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth. TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer. SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored. HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ. 3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode. SQ1: SQ1 uses the highest compression for resolutions greater than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images. SQ2: SQ2 uses the highest compression for resolutions less than 1600 x 1200. You can choose high compression to reduce noise or normal compression to save more images.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Olympus Camedia D-435 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
