Hey, if your Dell 2335DN has a fuser error or low heat error first try cycling the power (powering off and back on the machine). If this doesn't fix it, you should replace the fuser (part# KW449). Here is a video showing how to replace it and where you can purchase one. Good luck!">
Just bridge the thermostat on the fuser and print happy...
Http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?treeid=341929
click on the fuser error and fallow the steps.
James
IMU, LLC
You should go to dell.com/support and put in the service tag in and check to see if it is covered under warranty, chat with a service tech there via the internet or by phone which ever you feel more comfortable with to find out a good way to get it repaired.
Rich Lilja
SOURCE: I have a Dell 2335dn,
Make sure the fuser is seated correctly and cycle the power (turn the machine off and back on). If the error continues try replacing the fuser (part# KW449). Iteminc has this in stock and ships same day. Here is a video that shows you how to replace it. Good luck, and thanks for using FixYa!
