Question about Ricoh 6513 Copier
Error code I am receiving an error code SC385 and cannot use the copier at all. Does anyone know what this error code is and a fix for it? Thanks
    Problem Solver:
  • 18 Answers
ID sensor dirty or  faulty ID sensor, Old drum, worn developer. When cleaning sensor be careful if you use a vacumcleaner can blow sensor with static. Ideally call service engineer.
Posted on Oct 15, 2007
  • 24 Answers
Sc 385 is ID sensor vsg adjustment error.Clean the ID sensor.If the developer life is expired replace the same
Posted on Sep 06, 2007
    New Friend:
RICOH AFICIO 3228C
SC 385
WHERE IS THE ID SENSOR???
Posted on May 05, 2010
    Habit-Forming:
  • 21 Answers
The ID sensor is the Image Density sensor. It meassures the toner density on the drum under spesific conditions (laser intensity and different voltages). Worn drum or old developer can not generate full color (toner) coverage. The ID sensor value helps the machine to adjust to worn drum and old developer - and still make OK copies.
Posted on Dec 08, 2008
Where is the ID sensor?
Posted on Nov 06, 2008
SOURCE:
Sc385
Try looking in the FIXYA section for electronics.
Mar 06, 2014 | Ricoh Aficio 3228c Copier
ERROR CODE SC385
This code relates to the ID sensor voltage check which didn't fall between the accepted levels (4V +/- 0.5V). Possible causes: defective sensor, dirty sensor, loose/disconected wire on the sensor, dirty drum.
If you need a manual with further details, it's available here. There's also some other helpful hints for this printer on that page.
Dec 06, 2011 | Ricoh Aficio AP3800C Laser Printer
Error code t84 ???????? anyone
Hi stuiejohnsto,
As far as I know there is no error code t84. The closest code that has the numbers 84 in error code CC-184.
Anyways, whatever code you may have, it's worth turning the machine off for 10 seconds by the Main ON/OFF swich (inside front door on the left).
With any luck your code should disappear. If not, can you let me know if it gives you a different code to t84
Thanks
Good luck
Tam
Mar 22, 2010 | Konica Minolta Bizhub c203 Copier
Error sc385 ricoh 6513
SC385: Vsg Adjustment Error
The LCD displays SC385 when the output from the ID sensor is found to be
outside 1.8 ± 0.05 V during Vsg adjustment.
Turning the power off then on resets this condition. However, SC385 is lit again after the end of each copy job even when this SC condition is reset by turning the power off then on. Toner is still supplied, but using fixed supply mode, until a subsequent Vsg adjustment is successful.
For Starters
· Dirty ID sensor
· Poor connection of connector
· Defective ID sensor
· Poor cleaning
1. Clean the ID sensor.
2. Check if the sensor connector is properly connected.
3. Replace the ID sensor.
4. Check the drum cleaning unit.
Dec 20, 2009 | Ricoh Office Equipment & Supplies
I am receiving error code 39,012.40:76243 on C2424
Replace document feeder. 004k07270 $390.00
Sep 04, 2009 | Xerox C2424 Copier
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
this error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Jul 22, 2009 | Canon imageRUNNER 5000 Copier
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
Need to reset purge counter due to error 46
not easy and worth to fix it since ink jet printer sare cheap. New one include all the ink cartridges which are expensive too.
gar266
Jul 30, 2008 | Brother MFC 420CN All-In-One InkJet...
Error code:0150:0081084 anyone know this code and how to fix thanks
A firmware upgrade should solve the problem
download the file (i received one a year ago ftom Kyocera), put it on usb stick
power off the machine, installed the usb stick (at the back) and power on
after upgrade problem should be gone
Jul 17, 2008 | Kyocera FS-3900DN Laser Printer
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
Ricoh 6513 Copier Logo
2,016 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
