My screen is not cracked, under the screen is straight lines and vertical lines when I turn the power on. my daughter jumped in the middle of the screen.
If it is likely that there is still moisture in it, turn the device off and soak it in a bad of uncooked /dry rice for a couple day (unless you can get a hold of some large Desiccant bags to use) and it should sap the rest of the moisture out of it for you.
If you hold your phone upright while taking a video, you've surely seen the horrific end results. When you try to play the video back on any other display, roughly 70 percent of the screen is occupied by black bars.
Horizon is a video-recording app with a twist-quite literally. Using your phone's sensors, the app ensures that you're always filming in landscape mode regardless of how you hold your phone. With your camera's viewfinder locked onto the horizon, you can turn your phone every which way and the video will remain level.
Sorry to hear this Jennifer. First thing that comes to mind is that it is a crack in the under screen glass. You can test this by applying slight preasure on each side and see if you see any rainbow colors or if you lose the PITURE on the screen. Has it show a screen on both sides of the line? These tablets are known to have issues relating to even the slighted shock or sometimes its caused due to surges from the charge unit. If you have this happen and it does get worse it is about 40 dollars to have a new screen installed. Ill follow your post to see if I can help you further.
Good luck
Chadman
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
this is a broken Lcd (the screen is distorted by the lines or no picture at all)
this is just a broken digitiser (the screen below the broken glass works fine )
Unfortunately, if the display is cracked, you will need to take your daughter's tablet to be serviced by a repair technician. Otherwise, you will not be able to see anything on its screen or make the touch matrix work.
try connecting it to a pc with usb cable if it charges then its the power supply if the same issue occurs then the device has a problem most likley battery is faulty
